Online Now [1386]:
Visitors: 1385
Today: 175517
Total: 151304457
Forums › The Car › 206 Problems › 206 2.0 starting problems
spiritse
PostPosted: Mon Aug 06, 2012 4:00 pm Up
my question is about the crankshaft sensor, when I start the 206 it runs fine, but if it stalls then it wont start for a while, warm or cold. I had something similar with a renault scenic. it turned out the crankshaft sensor is prone to causing problems and they need cleaning.
Does the 206 sensors also have the same problems?
206 2.0HDI 2001
PostPosted: Mon Aug 06, 2012 4:14 pm Up
not an uncommon fault on 206
spiritse
PostPosted: Tue Aug 07, 2012 11:32 am Up
I took the sensor off and cleaned it up, but same problem.
Have to just try the glow plug relay first, although it did come on once yesterday.
206 2.0HDI 2001
