Latest: lio94
Overall: 17181
Online Now [124]:
Visitors: 123
Today: 60289
Total: 141078571
Forums › The Car › 206 Problems › 206 pulling to left under breaking
chambie1980
PostPosted: Wed Aug 08, 2012 12:18 pm Up
could anyone help with this problem ? I recently bought second hand alloys wheels and since putting them on I get pulling to the left under breaking. it's not everytime I brake but is a huge worry when it's dragging you towards ditches and not expecting it. also have constant wheel wobble around the 65-70 mph mark if anyone can help me with that also. any comments are much appreciated
chambie1980
chambie1980
PostPosted: Wed Aug 08, 2012 12:21 pm Up
braking* not breaking... had to correct myself before anyone else does lol
chambie1980
DeadEyePaul
PostPosted: Wed Aug 08, 2012 12:28 pm Up
Did you get your wheels balanced prior to fitting them?
chambie1980
PostPosted: Wed Aug 08, 2012 12:32 pm Up
no I didn't. ( I'm guessing huge mistake ) I have it booked in for 2 new front tyres at the weekend, which will obviously be balanced. should I also get the rear wheels balanced to be safe ?
chambie1980
PostPosted: Wed Aug 08, 2012 12:36 pm Up
What wheels did you have on before?
Steel or alloys?
chambie1980
PostPosted: Wed Aug 08, 2012 12:39 pm Up
I had alloys before pal. they were 14 inch and I've gone to 15 inch ( if that matters ) I've seen the new wheels I have one a lot of fords ( multi spokes ) and the balance weight would have to sit on the inner side but I can't see one on either
chambie1980
chambie1980
PostPosted: Wed Aug 08, 2012 12:46 pm Up
My ford comment was probably irrelevant lol
chambie1980
PostPosted: Wed Aug 08, 2012 12:47 pm Up
You could try swapping the wheels N/S to O/S to see if it starts pulling to the right. If it pulls to the right then it is probably the wheels, if it continues to pull to the left then I'd be looking at the suspension and steering.
Have you checked to see if the tyres are directional?
chambie1980
PostPosted: Wed Aug 08, 2012 1:13 pm Up
all rotations are good except for passenger rear. should I see if they can rectify this when I have the two front tyres replaced and maybe swap the wrong rotation tyre ?
chambie1980
chambie1980
PostPosted: Wed Aug 08, 2012 1:17 pm Up
I will try swapping o/s and n/s fronts and see what results I get. will do that tomorrow and get back to you pal.
chambie1980
Nick_C
PostPosted: Wed Aug 08, 2012 1:36 pm Up
Has this with a 106 and was tyres, but could alo be bushes.
Nick
Nick
Peugeot 206 GTI 180
Currently breaking a 2001 206 GTI - please contact for details/parts
chambie1980
PostPosted: Fri Aug 10, 2012 11:26 am Up
thanks guys for your help and comments, just got back from having tyres replaced and wheels balanced. I no longer have pulling to the left under braking and wheel wobble is now sorted. problem was worn tyres and no balancing weights ( to be honest they were worn to slicks on the inside of fronts... past user must have been an angry driver lol ) anyway thanks again for taking the time to comment and help
chambie1980
LeeMaddern
PostPosted: Fri Aug 10, 2012 11:44 am Up
Bottom arm bush maybe mate
Jack car up, so wheel is of the ground.
Then use a bar to left the wheel up & down, check for play in the bushes
While your at it, check wheel bearing. While cars jacket up, move the wheel back and forth.
By that i mean, push away from you at the top
Of the wheel, pull towards at the bottom.
If there is any play, new wheel bearing.
More photos on FaceBook - www.facebook.com/lmaddern1
LeeMaddern
PostPosted: Fri Aug 10, 2012 11:48 am Up
Sorry my spelling & gramma is shocking as im real busy at the moment.
DeadEyePaul
PostPosted: Fri Aug 10, 2012 12:42 pm Up
Glad you sorted it! Knew it wasn't anything mechanical as you stated you just started with the faults when you fitted the wheels Very Happy
