Online Now [225]:
Visitors: 224
Today: 39892
Total: 143238078
Forums › The Car › Request a how-to › how do I remove the outer black plastic door trim?
Forum IndexRequest a how-to
PUGPAUL
PostPosted: Fri Aug 10, 2012 5:39 am Reply with quote Up
how do I remove the outer black plastic door trim [body guard / side mouldings] please?
many thanks.
Peugeot 206 HDi (1.4cc) 'eco' - 2005
-Dave-
PostPosted: Fri Aug 10, 2012 5:56 am Reply with quote Up
Trade Rating: +36
Open the door. Grab it from where it folds in then push from the other end.
Ex 206 Owner.
iainlovatt
PostPosted: Fri Aug 10, 2012 6:02 am Reply with quote Up
Just pull it off but watch out you will guarantee to break the plastic lug clips that hold it on so best to go buy some before hand they are like 3p from peugeot!
(My Garage)
-Dave-
PostPosted: Fri Aug 10, 2012 6:04 am Reply with quote Up
Trade Rating: +36
You will break them if you pull it off. Slide it out slowly and all clips shoud be intact. Your a bloody cowboy Iain Laughing
Ex 206 Owner.
iainlovatt
PostPosted: Fri Aug 10, 2012 6:06 am Reply with quote Up
woohoo! that would explain it!
(My Garage)
PUGPAUL
PostPosted: Fri Aug 10, 2012 6:09 am Reply with quote Up
Push from the 'pointy end' BACKWARDS [toward the rear of vehicle]?
Is there a clip or fastener at the 'folded end' [door opening end] that needs to be pulled forward, away from the door a little bit first?
many thanks!
-Dave-
PostPosted: Fri Aug 10, 2012 11:58 am Reply with quote Up
Trade Rating: +36
Yes
No, Just get your nail's behind it and ease it forward a little bit then push from the other end.
many thanks!
Ex 206 Owner.
PUGPAUL
PostPosted: Sat Aug 11, 2012 4:44 pm Reply with quote Up
-Dave- wrote:
Yes
many thanks!
In the end it actually pushed forwards, toward the front of the car to release the clips [at back].
P6RAF
PostPosted: Fri Jan 18, 2013 12:00 pm Reply with quote Up
Here's my experience...
Firstly push/slide the trim as far back towards the opening end as it will go then lift the trim away from the body work at the door opening end. BUT make sure you lift/pull the trim at least an inch away from the panel then using your palm nudge the whole trim towards the front of the door. Most clips will then slide out of the back of the trim staying in the door. Maybe the ones closest the lifted end will break so make sure you have a few spare ready.
However, if you do as I did Crying or Very sad and only lift the trim a centimeter or so away then nudge it forward it breaks/cracks the molded tab from the trim.
Then you're left with a gluing job to try to strengthen the tab so that when refitted it sits flush to the body work. Get this wrong and it doesn't ever sit tightly to the body work and looks terrible.
The remaining clips left in the door can be removed without breaking them if you are careful. I found if you turn the clips so they are an angle, like a diamond, then using some, flat, stiff plastic like a ruler you can push in the coned end from a 3 O'clock position in enough to enable the clip to be pulled/wiggled out.
Good luck
2004 206 HDi GTi, Obsidian Black.
VW Polo 1.3 GL - 205 GTI 1.6 - 306 D-Turbo - First 205 GTI 1.9 track car - Second 205 GTI 1.9 Track car - 106 XLD - Impreza WRX - 406 V6 - 206 HDi GTi
Rob206
PostPosted: Fri Jan 18, 2013 12:29 pm Reply with quote Up
Was just about to ask same thing lol cheers
  Quick Reply
Username:
Message:
Quote the last message
