Forums › The Car › Request a how-to › 1999 1.4 8v core plug behind camshaft pulley |
Posted: Fri Jan 25, 2013 5:23 am |
hi there,
need some help, my core plug behind my camshaft pulley is leaking after car froze up,
was thinking of removing engine mount removing pulley and replacing,
just wanted to know if its safe this way as i dont want camshaft to move while doing it,
cheers
| keep on to the end of the road | |
Posted: Fri Jan 25, 2013 10:46 am |
If the car had the correct amount of antifreeze in it then it wouldn't have popped the core plug out during the cold weather IMHO
Posted: Fri Jan 25, 2013 11:17 am |
I got to the fourth line and gave up reading due to a lack of paragraphs.
Posted: Fri Jan 25, 2013 6:05 pm |
bump
You can post new topics in this forum You can reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
