Latest: lio94
Overall: 17181
Online Now [321]:
Visitors: 320
Today: 19266
Total: 142062774
Forums › The Car › 206 Problems › oil leak
oil leak
tom2581
PostPosted: Fri Aug 10, 2012 10:03 am Up
It appears the lack of oil appears to be a leak of all things lol, noticed a few patches on the drive and a quick look underneath I noticed the sump was covered in oil, from just above the filter down, you could see where it had ran down the filter, just looks like its been spraying whilst driving, the back of the sump was dry, so I've wiped it clean with some rag and left it to see where the leak come from.
I've noticed since.doin that there's some more oil near the filter on the sump, and the sump plug is still dry so I'm assuming its either a loose filter, broken seal and hopefully not the sump gasket.
Is this a common problem cars a w reg Gti 137
Obviously 1st port of call drop oil change filter and new seal on sump plug, any advice on anything else it could possibly be
PostPosted: Fri Aug 10, 2012 10:07 am Up
There is a known issue with oil leaks from behind the flywheel due to a dodgy seal on a blanking plug on the early EW10 lumps.
tom2581
PostPosted: Fri Aug 10, 2012 11:08 am Up
Mmmm ok its deffo near the filter though ill check again 2moro at work now see what the sump looks like hope it ain't nothing major I don't get paid for another 3week Sad
PostPosted: Fri Aug 10, 2012 11:15 am Up
Then change the filter and its gasket and also check the gasket between the oil filter housing and block.
tom2581
PostPosted: Sun Aug 12, 2012 5:46 am Up
had my mate check it out, its the gasket between the oil filter and block, problem is i cant seem to find a gasket anywhere, and is it a big job to replace looks like the throttle body and inlet gotta be removed to get to the housing, so i'm assuming them gaskets will also need replacing
