Latest: lio94
Overall: 17181
Online Now [170]:
Visitors: 169
Today: 79122
Total: 140717116
Forums › The Car › 206 Problems › fuse blowing when flashing lights
Abyzmal
PostPosted: Fri Aug 10, 2012 12:20 pm Up
Just had some morettes fitted, all work ok except when I use the flash, then the fuse blows...bit stumped any ideas?
206gti owner from 22/7/2011
QuArTz
PostPosted: Fri Aug 10, 2012 12:33 pm Up
Trade Rating: +16
Think your morettes need their own earth, somebody will correct me if im wrong.
mtempsch
PostPosted: Fri Aug 10, 2012 12:41 pm Up
Exactly which fuse?
How are they connected - plain H4 plug, adapter w relay? Is the dipped beam meant to remain on along with the full beam?
What lights did the car have from factory, H4 or H7? Pre plexed or multiplexed wiring?
Silvermetallic 2004 206 RC
DeadEyePaul
PostPosted: Fri Aug 10, 2012 12:46 pm Up
Both my morettes have an earth wire. Even seen a set where one side was fused.
PostPosted: Fri Aug 10, 2012 4:09 pm Up
There wired up incorrectly.
Abyzmal
PostPosted: Sat Aug 11, 2012 2:21 am Up
H4 lights into adaptors from a h7 both have been earthed. Car is multiplexed, fuse is bottom left under the bonnet
