Posted: Sat Aug 11, 2012 11:23 am |
Posted: Sat Aug 11, 2012 12:08 pm |
Renault Clio 1.5 dci uses a short one, maybe 106?
Posted: Sat Aug 11, 2012 12:50 pm |
Steve206 wrote: |
Renault Clio 1.5 dci uses a short one, maybe 106? |
could be 1.5 dci;
i shall see if there is any oil leak from the filter housing first.
Posted: Sat Aug 11, 2012 1:00 pm |
Seabook wrote: |
Steve206 wrote: |
could be 1.5 dci;
Thanks |
did it used to have the plastic housing?
If so you can get a oil filter insert to use the shorter metal ones.
I did this on mmy 106 to get a 4 branch manifold to fit. pretty straight forward..
Think I might have the insert somewhere
Posted: Sat Aug 11, 2012 1:04 pm |
xdoddyx wrote: |
Seabook wrote: |
Steve206 wrote: |
could be 1.5 dci;
Thanks |
Think I might have the insert somewhere |
nope. it always use M20x1.5 metal can, 90mm height if that help.
all i need to know is which one is the shorter oil filter that would fit
(shorther than 3")
Posted: Sat Aug 11, 2012 2:50 pm |
defo the dci one then
Posted: Sat Aug 11, 2012 2:51 pm |
Posted: Sat Aug 11, 2012 2:57 pm |
yes, i found that on ebay too.
Posted: Thu Aug 16, 2012 4:06 pm |
finally manage to dig out the correct filter.
indeed it is LS932. steve was spot on
