Online Now [36]:
Visitors: 35
Today: 8043
Total: 116659939
Forums › The Car › 206 Problems › Short oil filter
Short oil filter
PostPosted: Sat Aug 11, 2012 11:23 am Up
By any change people got the parts number for a shorter version compare to the original metal can oil filter (1109 T0)?
i am fairly sure i saw it (made by bosch or bosch packing) from a random search on goolgle before but i forget to drop down the parts number Sad
At the moment i am using the filter off from impreza but i am worry that i might leak through the seal as the seal is a bit smaller compare to the oem one.
PostPosted: Sat Aug 11, 2012 12:08 pm Up
Renault Clio 1.5 dci uses a short one, maybe 106?
PostPosted: Sat Aug 11, 2012 12:50 pm Up
could be 1.5 dci;
i shall see if there is any oil leak from the filter housing first.
xdoddyx
PostPosted: Sat Aug 11, 2012 1:00 pm Up
Seabook wrote:
could be 1.5 dci;
did it used to have the plastic housing?
If so you can get a oil filter insert to use the shorter metal ones.
I did this on mmy 106 to get a 4 branch manifold to fit. pretty straight forward..
Think I might have the insert somewhere
Moonstone HDI
PostPosted: Sat Aug 11, 2012 1:04 pm Up
xdoddyx wrote:
Seabook wrote:
could be 1.5 dci;
nope. it always use M20x1.5 metal can, 90mm height if that help.
all i need to know is which one is the shorter oil filter that would fit Laughing
(shorther than 3")
PostPosted: Sat Aug 11, 2012 2:50 pm Up
defo the dci one then
PostPosted: Sat Aug 11, 2012 2:51 pm Up
www.ebay.co.uk/itm/Ser...27bd2a37d7
PostPosted: Sat Aug 11, 2012 2:57 pm Up
yes, i found that on ebay too.
PostPosted: Thu Aug 16, 2012 4:06 pm Up
finally manage to dig out the correct filter.
indeed it is LS932. steve was spot on
