Latest: sparrowdclxvi
Overall: 17139
Online Now [109]:
Visitors: 108
Today: 27908
Total: 113517332
Forums › The Car › 206 Problems › overheat in gti 138 2000
scoop
PostPosted: Fri Aug 17, 2012 6:08 am Up
i still have the same problem that the engine temperature rises till 100 degrees and stays at that point then when i press the fuel pedal few times the the low speed fan kicks in and the temperature goes back to 90, i have turned on the a/c to check if the low speed fan kicks in with it or not and fortunately it worked and i disconnected the low speed fan resistor to check if its broken but the as soon as i disconnected the resistor plug the low speed fan stopped so that shows that the low speed fan resistor is working fine, and i have cleaned the temperature sensor (green one) and plugged it back and still the low speed fan doesn't kick in when it reaches 90 degrees or above, i have to admit that both fan speeds works fine with the a/c, but with engine temperature issues it's not functioning with low speed fan, only high speed works when temp rises above 100 degrees. i also wanted to know what is the sensor that is located below the green temp sensor which is also connected with 2 wires only maybe that could be a factor for the temperature problem, i just noticed that the engine didn't start when i unplugged that plug, and also another thing i need to tell is that i removed the thermostat for better engine cooling when running.. so please tell me what could cause the the slow speed fan for not working with increasing temperature??
ahmed
RMS-GTI
PostPosted: Fri Aug 17, 2012 6:10 am Up
The low speed fan should kick in at 99/100.
With the AC on it should never really get that hot because the fans keep it cool enough
Black 03 GTI. Silver 05 GTI 180
138Andy
PostPosted: Fri Aug 17, 2012 7:39 am Up
:/ what other sensor ?
138Andy
PostPosted: Fri Aug 17, 2012 7:47 am Up
the low speed fan could be effected by anything from dodgy wiring the relays are known to cause problems from corrosion, i myself had to replace and rewire the whole radiator fan system because it was all green and broken only takes around 30minutes - 1hour depending if you have the correct tools , soldering iron , new relays , enough electrical cable to rewire this area
you could also try a new resistor there only £5
you may have a faulty sensor take it to a garage and have them run a diagnostics on your can and see if there are any problems
PostPosted: Fri Aug 17, 2012 8:26 am Up
I'd remove the resistor so the low speed fan becomes high speed!
Low speed fan might stop working because the power has shifted to make the higher speed fan work. I can't remember how it's wired exactly.
Green sensor is the coolant temp sensor. This tells the ECU the coolant temperature. The ECU then switches the relays for the cooling fan.
scoop
PostPosted: Fri Aug 17, 2012 9:03 am Up
the black plug just below the green cable by 4cm
ahmed
scoop
PostPosted: Fri Aug 17, 2012 9:32 am Up
if the wires or resistor where damaged then the low speed fan wouldnt have worked with the a/c , right?
ahmed
scoop
PostPosted: Fri Aug 17, 2012 10:21 am Up
i have just tested the engine and it turned out that the low speed fan kicks in at 100 degrees and drops it down to 92 , could it be a faulty temp sensor?
ahmed
138Andy
PostPosted: Fri Aug 17, 2012 12:00 pm Up
is that not normal ? :/ , mine goes a little above the 90 mark then turns on drops a little below 90 but your in egypt much hotter climate Smile could you not get peugeot or someone with the program on there computer to change what temp the cooling system turns on and off ?
scoop
PostPosted: Fri Aug 17, 2012 1:21 pm Up
it does the same thing in winter, weather is not an issue Smile
ahmed
