Latest: lio94
Overall: 17181
Online Now [89]:
Visitors: 88
Today: 112060
Total: 140588972
Forums › The Car › 206 Problems › Sidelights not working + soft boot
jas915
PostPosted: Sat Aug 18, 2012 7:31 am Up
Hi 03 reg 206, the side lights dont work.
With ignition off nothing, with ignition on dipped lights come on(after a few seconds) when the stalk is moved to sidelights. Lights work as normal if going straight to dipped( ign on or off)
Also noticed the indicators don't work if switch is in sidelight position.
Any ideas?
Im a little worried about investigating further as would need to disconnect the battery, how can i soft boot if the side lights don't work??, assuming i don't fix the fault. Could i just go straight to dipped, or put an indicator on instead of the sidelights.
oh one other thing are the wipers supposed to go to intermittent when you stop at junctions? because mine do
Cheers
hello
PostPosted: Sat Aug 18, 2012 9:01 am Up
Sounds like you have a faulty com2000. There are about £150 to buy new from ECP dependant on model, and take about 20 minutes to fit.
jas915
PostPosted: Sat Aug 18, 2012 10:09 am Up
oh ok, would it be ok to disconnect the battery still following the guild on here with such a problem? or will it all go wrong, never work and cost even more.
Wanting to change what looks like the original battery and fit and after market stereo
thanks jason
hello
PostPosted: Sat Aug 18, 2012 10:15 am Up
Try a software reset, or has a fuse blown?
