Latest: heikkisj
Overall: 17126
Online Now [43]:
Visitors: 42
Today: 14056
Total: 100228441
Forums › The Car › 206 Problems › Another new problem
Another new problem
PostPosted: Fri Aug 17, 2012 7:57 am Up
Well another day and another problem for my 206 Sad
went to leave the house for work this morning and problems straight away Crying or Very sad
started it up and straight away it was struggling to idle properly, gave it a little gas, then the idle dropped again to just under 500rpm, tried to give her a little gas again but this time as the revs were at 500rpm the engine struggled to pick up.
It did this for about 3 minutes then the revs started to pick up to 1000rpm when the engine light came on and stayed on, when the engine was turned off the radiator fan was on but couldn't understand why as the engine didn't have time to get hot enough.
Tried it again when I got home and all the above happened again, coolant and oil levels are fine, tps and crankshaft sensor have been replaced so a bit stumped as to what it is other than an electrical fault.
DeadEyePaul
PostPosted: Fri Aug 17, 2012 8:00 am Up
mine does this, well it did before the engine upgrade ONLY in the hot weather. I found by letting the fuel pump prime before turning ignition fully makes it start better. try that?
PostPosted: Fri Aug 17, 2012 11:32 am Up
Do you own pp2000? I think you should invest in it! Coolant sensor? Thinking engine is warmer than it is, would cause fueling and fan issue?
PostPosted: Fri Aug 17, 2012 12:01 pm Up
afraid not mate, going in garage on wednesday to source the issue and have the mot done then it's up for sale
PostPosted: Fri Aug 17, 2012 1:56 pm Up
would say coolant temp sensor possibly buddy Sad
PostPosted: Fri Aug 17, 2012 2:01 pm Up
Cheers Matt, if it is just that and cheap enough to sort may risk taking it to castle combe that sat, still waiting for a reply from my brother
PostPosted: Sat Aug 18, 2012 1:47 am Up
hopefully will be that simple Smile
if you bring yours im sure it will make it but if we meet somewhere on the way and drive up together at least if you get a problem you wont be left on your own then Smile
PostPosted: Sat Aug 18, 2012 3:02 am Up
haha Smile cheers mate
Would a faulty engine temp sensor cause the engine to sound and feel really lumpy on start up? Me and dad been discussing it also and think maybe the fuel pump could be behind the engine misbehaving but agree with you with regards to the engine temp sensor being faulty causing the fan to kick in, will know wednesday what it is hopefully although there was a nice purple ek civic which I could always sweet talk them into swapping Laughing
PostPosted: Sat Aug 18, 2012 3:21 am Up
i think engine temp sensor=coolant sensor and is very easy to tell if they are faulty or not
PostPosted: Sun Aug 19, 2012 8:59 am Up
Been looking up symptoms and causes of a faulty engine temp sensor and it sounds like it could be that
PostPosted: Sun Aug 19, 2012 9:46 am Up
a live data read would tell if it is faulty or not
PostPosted: Sun Aug 19, 2012 9:59 am Up
Tbh, if we ever suspect a coolant sensor fault we just replace it
They arent expensive, and are a 5 minute job (ps check the connector for water residue and check the connector for corrosion as they do leak)
PostPosted: Sun Aug 19, 2012 10:02 am Up
Got to wait til wednesday for that mate but just been outside to check on oil levels etc, started the car up and it sounded fine, fuel pump was heard starting up and everything seemed fine, left the engine running for 3 minutes and it sounded fine, no struggling to tick over or irreatic revs, not even the sound of the fan cutting in or the engine light coming on Smile
still, not going to drive it til it has to go in the garage and they have good luck, once all sorted, up for sale it goes
