Online Now [1245]:
Visitors: 1244
Today: 128001
Total: 151259896
Forums › The Car › 206 Problems › DPF?
DPF?
stickman
PostPosted: Wed Aug 15, 2012 7:26 am Up
hello all
i have had a quick seach and can't get a definate answer.
Does my 2003 2.0 Hdi have a DPF? i am curious to see if it has becasue ive had a AntiPollution fault and i am getting the codes read tomorrow ive had some strange syptoms since this fault came in
Overrunning when i turn the engine off
the car will not go much more than 40 even with my foot planted to the floor
engine seems to skip or jump slightly when idle.
its kinda got me a little paranoid about using my car now so ive arranged to get the fault codes read but is there any idea whats causing this?
i do have a leaky Injection pump and diesel gets everywhere (i have placed an order for a replacement gasket to re seal it) could it be that diesel is leaking into or onto one of the sensors causing it to trip?
cheers
03 China Blue Dturbo
PostPosted: Wed Aug 15, 2012 8:03 am Up
Only the 1.6HDi has the DPF.
lmilligan
PostPosted: Wed Aug 15, 2012 8:09 am Up
No only the 1.6 HDi's have the DPF system
RMS-GTI
PostPosted: Fri Aug 17, 2012 6:13 am Up
I would possibly guess at the in tank pump. However a leaky HP pump possibly lettin air in?
As guys above said the 2.0 90 in the 206 didnt have a DPF
Black 03 GTI. Silver 05 GTI 180
wifes206
PostPosted: Fri Aug 17, 2012 6:32 am Up
What sort of AP system does the 2.0hdi have then?
206 2.0hdi(04)
RMS-GTI
PostPosted: Fri Aug 17, 2012 7:09 am Up
It has a cat/particulate filter but it is an 'old school' system as in it is just a traditional filter with no electronic control or additive
wifes206
PostPosted: Sat Aug 18, 2012 10:40 am Up
So what's the eolys fluid for in the tank next to my
Fuel tank then?
206 2.0hdi(04)
PostPosted: Sat Aug 18, 2012 12:17 pm Up
Fuel tank then?
You have either got a 1.6hdi, or you dont have the elyos. Pics?
wifes206
PostPosted: Sat Aug 18, 2012 3:43 pm Up
Steve206 wrote:
Fuel tank then?
I will, i'll get a pic I looks like a little tank thing next to my
main fuel tank made out of the same material.
I even phoned peugeot up once about cambelt, guy on the phone
Asked for the mileage, so I told him and he said that's ok but
Some fluid wants toppin up and particular filter change in at 58,000miles
206 2.0hdi(04)
wifes206
PostPosted: Tue Aug 21, 2012 5:51 am Up
My bad, looks like its an extension of my fuel tank with a heat shield on
so I've not got eolys, that's great news!
206 2.0hdi(04)
