Latest: Andyblue64
Overall: 17123
Online Now [43]:
Visitors: 42
Today: 41158
Total: 98312752
Forums › The Car › 206 Problems › aerial hole size
aerial hole size
Neil206
PostPosted: Thu Aug 30, 2012 7:20 pm Up
size / shape before i remove it? and will a motor factors stock a bung of suitable / size shape / water protection?
dont want to remove it yet as it doesnt let water in
also, how to remove the actual aerial from its base? tried twisting and pulling, but nothing?..... am i being a bit of a drongo or what?
cheers in advance
206
mehoolkmusic
PostPosted: Fri Aug 31, 2012 8:08 am Up
If you peel some of the headliner off if its rear mounted there is a nut you unscrew to remove it, if it is front mounted simply remove the interior light and the nut is there to unscrew....
Left French. Drive a Astra coupé 2004
www.soundcloud.com/mehoolkmusic
