Online Now [1763]:
Visitors: 1762
Today: 148987
Total: 152187762
Forums › The Car › 206 Talk › Car tilted
Car tilted
Forum Index › 206 Talk
karimali831
PostPosted: Wed Sep 05, 2012 1:05 pm Up
After all these months I've just realised the car is tilted to the right, there is almost no arch room on the right with plenty on the left. I want to get the car lowered but not sure if I will need a new torsion bar? If not must I only get the front lowering springs?
Thanks for any advise.
206 GTI 180
Sounds like the bearings are shot on the rear axle
anton1989
PostPosted: Wed Sep 05, 2012 1:11 pm Up
Trade Rating: +16
would that mean new axle or can they be fixed?
A18NHH
PostPosted: Wed Sep 05, 2012 2:14 pm Up
they can be repaired but i believe the costs mean you're probably better buying a 2nd hand axle
Wahoo!
Coolspot
PostPosted: Wed Sep 05, 2012 2:24 pm Up
I had that on my old axle, the car was lower on one side and you might notice one wheel leaning more at to top if you look from behind at 20 yrds.
look around for a young axle to avoid the next being a little wron too
206 3dr 1.4 GLX modified slightly, Lowered 35mm on full Gmax kit, 17" AEZ xylo alloys 205/45/17, 3.5" Savage back box,
PostPosted: Wed Sep 05, 2012 7:02 pm Up
Depends how far they've gone as to weather or not they have scored the beam. But usually by the time it gets to the stage you notice camber on the wheel it's too late and more economical to get a decent 2nd hand axle or a refurb one.
karimali831
PostPosted: Thu Sep 06, 2012 5:04 am Up
Will it matter if I am going to get it lowered anyway?
206 GTI 180
Coolspot
PostPosted: Thu Sep 06, 2012 5:32 am Up
If you axles fine lowering it will wear it out faster. (depending how low u go)
But my axle was lowered and had nackerd bearing and i could see the wheel wobbling and feel it when going around corners.
