Posted: Mon Sep 03, 2012 12:13 pm |
Only had one key for my car and lost it on the weekend
Anyone know the process and cost?
Will be ringing pug tomorrow as I guess that's the only place I can get a replacement ?
Posted: Mon Sep 03, 2012 12:16 pm |
Depends on which type of the many keys it is.
Peugeot main dealer will want to see your photo id & proof of ownership for the car before they even order / sell you a key.
ALL the keys will need coding with Peugeot Planet & you need the 4 digit security code before keys can be coded to the car.
The code you need is on the blue plastic security code card behind the silver scratch panel ( Peugeot can tell you the code for a small fee which if your ordering a new key they might not bother with but again photo id & proof of ownership before they will release the code )
Get the key / keys cut so you can load the car up & have it recovered to the Peugeot main dealer for them to be coded in.
Posted: Mon Sep 03, 2012 2:07 pm |
No sympathy tbh. Iv had my new 206 a week and within the first 2 days i have been trying to get a second key sorted.
Your in for a hefty amount to sort this out!
Posted: Mon Sep 03, 2012 2:16 pm |
One of the first things I did was get a 3rd key for my 206.
It came with the 2 original remote fobs so I got a 3rd standard transponder key to keep in my wallet as a emergency spare.
Standard non remote key can still disarm the alarm system.
Posted: Mon Sep 03, 2012 2:36 pm |
Cheers for replies , found online I can grt a blank for 60+vat , but then needs cutting and programming
I'm estimating around 130 ish
Posted: Mon Sep 03, 2012 2:47 pm |
Just looked on Peugeot Service Box & you may struggle getting a remote key from Peugeot as there is NO FURTHER PRODUCTION
Part number 6552 ZW normal locking one button remote key £85.75
Part number 6552 ZX remote deadlocking 2 button remote key £94.31
Replacement part number for both is 9170 N7 Standard NON remote key £25.66
Posted: Mon Sep 03, 2012 2:57 pm |
Well if I can get a non remote for now , it's better than nothing
Cheers again for that info
Posted: Mon Sep 03, 2012 2:59 pm |
Get ALL the keys you want first else you have to pay a 2nd time for coding
Posted: Mon Sep 03, 2012 5:54 pm |
i can get keys precut to chassis number. All you'd have to do is get somebody to program it/them to the car with the 4 digit pin which i can also get you
Although if the car has had locks changed at some point then keys cut to chassis won't work.
As somebody else has already said Peugeot have discontinued the type of remote you need. They've done the same with some 306/406 remotes which is a pain in the backside for me when i get customers calling for new keys
Craig
| Mobile remapping using the Alientech Kess V2. mobile diagnostics, fault code reading/clearing for most cars & some vans. Mobile car key cutting & programming for most makes! | |
Posted: Mon Sep 03, 2012 7:33 pm |
How much for u to precut a key? And how much usually to get it programmed in?? Thanks
| 206 gti180
106 gti show
saxo vtr runaround | |
Posted: Mon Sep 03, 2012 8:29 pm |
If anyone needs keys programmed with the 4-digit code, or codes read from car - or blanks, I can highly recommend Enigma of Ashford 01233 623236. They are far cheaper than the main stealer and really know what they are doing...
Just say Matt from Sinful Design sent you and I said you would get a discount
Posted: Tue Sep 04, 2012 2:52 am |
chimp3106 wrote: |
How much for u to precut a key? And how much usually to get it programmed in?? Thanks |
price depends on what type of key it is. A basic transponder key costs less than a 2 button remote key. Also if you have an existing key I don't need to get it precut as i have key cutting equipment in my van & would use your original key as a guide.
As for programming. I usually charge £30 within a 10 mile radius of my. Any further & I charge to cover extra fuel & driving time.
If you're wanting a full quote the best thing to do is send me a PM with your postcode, model & year of car & what type of key you want
Craig
Posted: Tue Sep 04, 2012 3:33 am |
Just rung peugeot and they quite 170 and 7-10 days
Posted: Tue Sep 04, 2012 3:34 am |
Anyone know anyone near Cardiff that offers the service?
Posted: Tue Sep 04, 2012 3:37 am |
Quick guess on what I could break the car for?
Everything worked bar ac, sports bumped wings and spoilers
