Posted: Thu Jul 14, 2011 4:28 pm |
Does anyone have one to hand? I know its in the haynes manual but i have left it at another house, and the only one i can find on line is very complicated!
Any help would be appreciated as there are 7 cables and i have only found out what 2 of them do so far!
Posted: Thu Jul 14, 2011 4:42 pm |
Year?
Posted: Thu Jul 14, 2011 4:44 pm |
doesnt matter on year tbh! My car doesnt have electric windows, but i have all the bits i need, just never got round to it until tonight
Just need an understanding what each wire does!
Posted: Thu Jul 14, 2011 4:47 pm |
They use different switches
Posted: Thu Jul 14, 2011 4:51 pm |
ahh i see what you mean, i got a just the electric window switch no mirror switch, the drivers one is automatic, the only thing i cant tell you is if it came out of a pre-plexed car or not.
Posted: Thu Jul 14, 2011 5:06 pm |
If you don't fit the one touch unit, the fuses will blow all the time
Posted: Thu Jul 14, 2011 5:14 pm |
| Lee wrote: |
| If you don't fit the one touch unit, the fuses will blow all the time |
Which cable is the one touch unit?
Posted: Thu Jul 14, 2011 5:20 pm |
Pins 1A and 2B
Without one-touch the drivers window won't work
Posted: Fri Jul 15, 2011 3:35 am |
hey lee could you tell me what colour's they are, as i dont have a haynes to hand!
Posted: Fri Jul 15, 2011 4:00 am |
Pin 1A = 6042 - mauve - Right-hand window down info
1B = 604 - grey - Left-hand front window command
2a = N/A
2B = 6052 - mauve -6052 : Right-hand window up info
3A = M603 = earth
3B = 608 - grey - Right-hand front window command
4A = 609 - orange - Right-hand front window command
4B = 6003 - Brown -Driver's window torque sensor info
Posted: Fri Jul 15, 2011 5:55 am |
| Lee wrote: |
2a = N/A
3A = M603 = earth
4B = 6003 - Brown -Driver's window torque sensor info |
Posted: Fri Sep 07, 2012 6:59 am |
My car have electric windows. I want(and i have) to install "Window and mirror control switch" with a button "A". But it(control switch) doesn't work: passenger window work normal, but driver's don't work.
Peugeot 206 wiring diagramm tell me, that i need "control switch with button A" and "one touch unit".
Can you tell what it looks like this "one touch unit" or give part number.
sorry for my bad english.
Posted: Fri Sep 07, 2012 7:14 am |
| zeato wrote: |
sorry for my bad english. |
click me
Posted: Fri Sep 07, 2012 7:31 am |
Be very careful swapping window switches. If you put a different type of switch in ie auto switch into a non auto loom (or the other way round, can't remember now), it has a habit of blowing fuses due to the wiring configuration.
Posted: Fri Sep 07, 2012 7:34 am |
I already have this unit.
Question: is it real that driver"s(button "A") motor have 2 mode(type of work)?
Yes, i lost 3-5 fuses javascript:emoticon('post','message',':oops:') .
I connect passengers window motor(and it work), but i can't driver's motor.
Thanks for help.
