Latest: kemppu
Overall: 17142
Online Now [102]:
Visitors: 101
Today: 6698
Total: 114046049
Forums › The Car › 206 Problems › Really need help asap!!
Nosvartu
PostPosted: Thu Sep 06, 2012 1:49 am Up
Morning. Ive woken up today to drive home from my girlfriends got in the and the clutch feels like its stuck down like its always engaged and no matter what i do i can't seem to unengage it. I don't live in leeds and don't know whete a garage is. Its semi drive able but i'm not sure if it would be a good idea. Please any help
Newby
shell-vt
PostPosted: Thu Sep 06, 2012 2:16 am Up
Trade Rating: +46
sounds like the thrust bearing
york 16,3
Nosvartu
PostPosted: Thu Sep 06, 2012 2:35 am Up
How much are they to replace?
Newby
shell-vt
PostPosted: Thu Sep 06, 2012 2:42 am Up
Trade Rating: +46
if im right , its a gearbox out job
york 16,3
Nosvartu
PostPosted: Thu Sep 06, 2012 2:51 am Up
So its even worse than i thought... RIGHT new seat Ibiza it is.
Newby
PostPosted: Thu Sep 06, 2012 2:52 am Up
Thrust bearings are cheap, but as said above need gearbox off to get to it.
Nosvartu
PostPosted: Thu Sep 06, 2012 2:56 am Up
Ill most likely get it repaired but as soon as i can sell this car its going as i've had nothing but trouble from my Peugeot. Which is actually really annoying because i like the look of the car i just wish they were built better.
Newby
PostPosted: Thu Sep 06, 2012 3:19 am Up
Do you mean the pedal is to the floor?
Hydraulic or cable clutch?
Nosvartu
PostPosted: Thu Sep 06, 2012 3:22 am Up
The clutch is in the normal position, it feels really light and it feels like its always engaged when its in gear it revs kicks in the speed then if i want to go faster i can't as its just like having the clutch pushed down.
Newby
ukskater01
PostPosted: Thu Sep 06, 2012 8:05 am Up
Sounds like your pressure plate has failed, happened to mine with the same symptoms. Best to get a clutch kit fitted although you might have to get someone to tow you if it's far to a garage
Domo
PostPosted: Thu Sep 06, 2012 8:13 am Up
Kinda what happened to mine. Get new clutch. Try not drive it. I did and my clutch fork smashed through my plate and then parts broke off into my gearbox and hada get it replaced too!
Nosvartu
PostPosted: Thu Sep 06, 2012 8:24 am Up
How much will this all cost me?
Newby
PostPosted: Thu Sep 06, 2012 8:26 am Up
big factor in it will be if you are attempting to do it your self?
as lot of the times it will cost you more in labour doing clutches / gearboxes etc.
Nosvartu
PostPosted: Thu Sep 06, 2012 8:46 am Up
ive got zero experience in anything like this. if i knew how or had someone to help me id give it ago i just don't want to balls my car
Newby
DeadEyePaul
PostPosted: Thu Sep 06, 2012 8:51 am Up
Your near the mechanic that is installing my v6 engine would you like his details?
m.facebook.com/?_rdr#!...1054813616
He might be able to use the clutch and gearbox from my old engine? I have a new clutch setup and gearbox on the v6
