Latest: ArtistKS
Overall: 17145
Online Now [60]:
Visitors: 59
Today: 12570
Total: 115974247
Forums › The Car › 206 Problems › Car splutters when revving really annoying
nemesislee
PostPosted: Sun Jul 08, 2012 8:58 am Up
I have a issue not calling it a problem yet as the car runs kinda ok. When I put my foot down on the accelerator quickly and let go the car almost stalls, the exhaust make a sound like spluttering. I'm also loosing some power when the car warms up too. Any ideas?
Another problem/annoyance is that my car makes a weird squeaking noise but it's on the passenger side, so it's not the cam belt etc.
Thanks in advance Smile
peugeot 206 silver 1.4ltr lx
Parkerspug
PostPosted: Sun Jul 08, 2012 9:04 am Up
coil pack on way out!!!
Ryan
nemesislee
PostPosted: Sun Jul 08, 2012 9:21 am Up
Honestly? I have been looking into the coilpack issues hmmm damn lol so the coil pack could be causing the loss of power and the spluttering?
martinius88
PostPosted: Sun Jul 08, 2012 9:39 am Up
coil or spark plugs.
206 2.0 GTi 138, Eibach: Pro-Kit, torsion bar adjusted, ULTRA angel eyes, Black Lexus rear lights, LED side indicators, Scorpion Cat back exhaust system, K&N Panel filter, theloudest.com speakers fitted all round, Sony HU.
Ibiza Cupra 1.8T 20V, JabbaSport Stage 2 Map, K03s Turbo, Forge 008 re-circ Dump Valve, N249/N111 bypass, H&R Lowering Springs, Forge FMIC. 225BHP @ 1.0 Bar. 0-60--5.6s, 1/4mile--14.2
My Old 206 GTi: www.206info.co.uk/Foru...39589.html
New Car - Ibiza Cupra: www.206info.co.uk/Foru...tml#530454
PostPosted: Sun Jul 08, 2012 9:50 am Up
Doubt its anything to do with the coil pack. If the coil pack was at fault it would splutter all the time, not just when you hit the throttle suddenly.
martinius88
PostPosted: Sun Jul 08, 2012 10:04 am Up
Depends how broken down the coil is, as obviously there is more work required from it when under load. So coils or plugs.
nemesislee
PostPosted: Wed Jul 25, 2012 2:18 am Up
am i correct in thinking that i need a 16mm spark plug socket? ordered new plugs and have a tool but need the correct socket size
martinius88
PostPosted: Wed Jul 25, 2012 2:44 am Up
I think its 16mm or 17mm cant remember off the top of my head I'm afraid.
nemesislee
PostPosted: Wed Jul 25, 2012 3:46 am Up
thats cool thanks just ordered a set from ebay means ive got another wrench but it comes with a 16mm and 21mm socket Smile just hoping this sorts the problem out, if not il be looking at another coil pack.
nemesislee
PostPosted: Tue Sep 04, 2012 5:19 pm Up
Well changed the coil pack and plugs but I still get the problem. When my car is really warm say in the 90s it really struggles with power anything else I can try?
Gavin28
PostPosted: Thu Sep 06, 2012 4:28 pm Up
If its pre-plexed I'd check the engine coolant sensor for the ECU
Gav
nemesislee
PostPosted: Fri Sep 07, 2012 3:26 am Up
how do i go about checking that?
Steve180
PostPosted: Fri Sep 07, 2012 5:54 am Up
If it's the sensor I think Gavin is talking about, it will be located in the outlet tank on the side of the block (thermostat housing its called if you don't work for Peugeot). It's unlikely to be that tbh but it's worth a check, a dodgy sensor is a dodgy sensor, cleaning it/ replacing it may help in other areas.
So you've changed the pack and plugs and still have a 'mis-fire/ revving problem'..... hmmmmmm, is it the TU3JP engine? (1.4 petrol?) If it is, have you checked the injectors? I did one a few days back, similar probs as you, tried new plugs and pack, didn't fix it, in the end it was the injector.
Could try that?
2004 206 GTi 180: 207.9BHP, 183.1 ft/lbs
