Online Now [1343]:
Visitors: 1342
Today: 143022
Total: 151274010
Forums › The Car › 206 Problems › GTI 180 hunting and vibrating
Go to page 1, 2, 3  Next
Lewis
PostPosted: Mon Jul 30, 2012 2:42 pm Up
Hi guys, just recently having a problem with the engine of my 180 hunting and the revs dropping in the first 10 seconds of start up. The car is vibrating quite badly at points within this first 10 seconds also. Any help would be appreciated. Thanks
Lewis
Tivoli LX 1.1
Black GTI 180
White VXR Burg
PostPosted: Mon Jul 30, 2012 2:46 pm Up
Checked the veeveetea?
Lewis
PostPosted: Mon Jul 30, 2012 2:51 pm Up
Might give it a clean again! I've had that before and it brought up the anti pollution fault, this isnt flagging up any codes :/ strangeeee
Tivoli LX 1.1
Black GTI 180
White VXR Burg
Lewis
PostPosted: Tue Jul 31, 2012 1:11 am Up
Did the same thing again this morning. Feels like its hunting and then the car vibrates like mad!!!
Tivoli LX 1.1
Black GTI 180
White VXR Burg
Lewis
PostPosted: Thu Aug 02, 2012 6:14 am Up
anybody else had this and got any input? Thanks guys!!
Tivoli LX 1.1
Black GTI 180
White VXR Burg
PostPosted: Thu Aug 02, 2012 6:50 am Up
Map sensor was recently suggested to me, unplug it and see how it goes.
Lewis
PostPosted: Fri Aug 03, 2012 1:51 am Up
cheers, will have a go at that this afternoon!
Tivoli LX 1.1
Black GTI 180
White VXR Burg
uttz
PostPosted: Fri Aug 03, 2012 3:45 am Up
im having this same problem but after its warmed up seems fine.. let me know what works
GTi 180 Obsidian Black
SW 1.6 16v Sahara Yellow
uttz
PostPosted: Fri Aug 03, 2012 3:47 am Up
nothing comes up on diagnostic too
Lewis
PostPosted: Fri Aug 03, 2012 11:25 am Up
Will do, I've had a clean of spark plugs which were very black :/ only 8 months old. Cleaned the VVT sensor, and cleaned the inlet pipe around the butterfly! Can't give you reliable results until tomorrow morning though that's when the answers will be really apparent when it's at it's coldest. The MAF sensor is next on my list but I couldn't work out which one it was, is it the yellow clip on the intake?
Tivoli LX 1.1
Black GTI 180
White VXR Burg
uttz
PostPosted: Sat Aug 04, 2012 6:51 am Up
checked out my pug expert friend person... said to do an intialization or whatever you call it...essentially resetting the ecu... wasnt able to do it yesterday cuz he was way to busy.. will let you know how it goes
reason he said so was that a guy with a 2.0 307 was having the same issue and ttried it and it worked..
Lewis
PostPosted: Sun Aug 05, 2012 2:38 pm Up
After cleaning spark plugs, VVT sensor and butterfly it seems to have solved the prOblem, the plugs were so black, is that normal? Only replaced in December 2011 :/
Tivoli LX 1.1
Black GTI 180
White VXR Burg
uttz
PostPosted: Sun Aug 05, 2012 7:14 pm Up
can i use carb cleaner to clean that stuff and u can take a pic of where the vvt sensor is... changed the plugs back in june trying to solve the probably didnt
138Andy
PostPosted: Mon Aug 06, 2012 5:29 am Up
mine does it every so often just rev it and goes back to normal not sure whats wrong , took it to Peugeot and they couldn't find nothing wrong with it
uttz
PostPosted: Mon Aug 06, 2012 7:41 am Up
this happens to me every morning..1st start for the day/ after a long sitting period...funny this is its a cold start as if it was winter but i like in the tropics :/
Page 1 of 3
