Latest: ArtistKS
Overall: 17145
Online Now [206]:
Visitors: 205
Today: 4121
Total: 116141186
Forums › The Car › Request a how-to › Anyone know how to fix Sunroof?
Forum IndexRequest a how-to
cbgl
PostPosted: Wed Apr 04, 2012 11:21 am Reply with quote Up
Surely someone on this forum has fixed 206 sedan or 206 GTI sunroof, if so please provide some Howto info.
Have 206 GTI & 306 XT N5
Lewis
PostPosted: Wed Apr 04, 2012 12:52 pm Reply with quote Up
what sort of fix? is it a leak or not working.. give people more info dude
Tivoli LX 1.1
Black GTI 180
White VXR Burg
PostPosted: Wed Apr 04, 2012 1:24 pm Reply with quote Up
What He Said so that we can help you.
cbgl
PostPosted: Wed Apr 04, 2012 3:12 pm Reply with quote Up
Just purchased the Cable Assy Kit 842461, plus Sunroof Buffer Kit, 841099 and are very keen to fit these replacement parts over what we call Easter long weekend. This sunroof is in very good condition but some plastic bits have become brittle, our summers are tough on plastics. Supplied Vin number to local dealer whom then supplied parts as requested. Someone suggested that cables are better if inserted from inside of car being underside of sunroof, is that the recommended procedure? My original intension was to do as much as possible from topside without attempting to remove headlining, hopefully someone may have completed this sunroof work already. Looking forward to all comments & suggestions, best regards to all.
PostPosted: Thu Apr 05, 2012 1:30 pm Reply with quote Up
I think you should take the head liner off,so that you can everything clearly,and manage to replace all the parts you need to fix.
cbgl
PostPosted: Fri Apr 06, 2012 3:30 am Reply with quote Up
Many thanks Timon2210, I have taken your advice and removed hood lining firstly, have removed glass roof panel & removed Aluminium section which contains the sliding felt panel, all went fine, only requires one torque size, did discover a few broken pieces inside channels, gave everything a thorough clean in preparation for fitting the new parts, removed sunroof motor, tested it, noted how far it travels, checked conditions, wear & tear etc.
Tomorrow I will insert new (lubicated) cables kit, plus will replace plenty of rubber slide faces with corner pieces, will report back to this forum with a report on progress, best regards to all
PostPosted: Fri Apr 06, 2012 12:48 pm Reply with quote Up
Glad that things are going well for you so far,well me looking for your update tomorrow,have a nice weekend,and Happy Easter Smile
snailer
PostPosted: Thu Sep 13, 2012 11:04 am Reply with quote Up
Hi
Can I pick your brains about your 206 sunroof?!?
I've got to do the same as you (sun does shine in the UK...occasionally!!!)
The plastic bits connected to the cable which grip the glass roof are broken
Do you need to do it from below or can it be done from above?
How do you get them out of the track and the new ones in? or is it obvious
when you remove the headlining...?
Do I need to remove the glass roof? is that easy to do?
Thanks v much in advance for any help you can give.
Tony
1999 206 1.1
  Quick Reply
Username:
Message:
Quote the last message
