Posted: Thu Sep 13, 2012 4:17 pm |
Hi guys, ive just bought my peugeot and ive got a proble
With the fasten seatbelt light, at least thats what i think it is, i took a photo but its not very clear, maybe someone will be able to tell from the position of it what light it is
It wont switch off and i dont know why!! Someone please help?? Thanks
Posted: Thu Sep 13, 2012 4:21 pm |
Posted: Thu Sep 13, 2012 5:32 pm |
This happened on mine I just disconnected battery for half hour and it turned off
Posted: Fri Sep 14, 2012 2:56 am |
Looks more like a non plexed 206 side airbag warning light.
Posted: Fri Sep 14, 2012 7:16 am |
can u not get a better pic?
Posted: Fri Sep 14, 2012 8:00 am |
MrBSI wrote: |
Looks more like a non plexed 206 side airbag warning light. |
I agree.
The seat belt light should be red, although the pic is that bad it could be anything.
I would try reactivating the passenger side airbag using the switch first just to rule that one out. The warning light is in a similar area to the pic.
Posted: Fri Sep 14, 2012 8:20 am |
SOrry ill get a better picture when i get my cr back from the garage, getting both wishbones replaced.
Posted: Sun Sep 16, 2012 5:46 pm |
Ive had a look in the manual and the light is the side airbags light can anyone tell me why it stays on?? Its really annoying
Posted: Mon Sep 17, 2012 9:25 am |
Jay0913 wrote: |
Ive had a look in the manual and the light is the side airbags light can anyone tell me why it stays on?? Its really annoying |
It stays on because there is a fault with the side airbag system.
With the ignition key REMOVED! ! !
Look under each front seat & check both the green & the red connector plugs, disconnect them both & give them a spray of electrical contact cleaner then reconnect them again.
If that doesnt cure it then you will have to have the srs system scanned for fault codes.
