Latest: eltel666
Overall: 17146
Online Now [135]:
Visitors: 134
Today: 14083
Total: 116151110
Forums › The Car › 206 Problems › Courtesy Light switch on Peugeot 206 Xline 2004
traffica1
PostPosted: Mon Sep 17, 2012 4:02 am Up
Hello,
Thank you in advance for you help.
I have a peugeot 206 Xline 2004, i am trying to plug an electrical after market addon to the car, and i want it to start up with the courtesy light, when i open the door i want the new added light to start up as well.
i cannot find the wire responsible for triggering the courtesy light.
Regards.
PostPosted: Mon Sep 17, 2012 4:44 am Up
I think the switches are built into the door catch.
You can connect straight into the interior light.
www.206info.co.uk/Foru...37584.html
traffica1
PostPosted: Mon Sep 17, 2012 6:30 am Up
Hello,
Thank you for your prompt reply.
i will attach a picture of my car with the addon.
I currently wired it to the speaker at the top left behind the mirror, but i want to wire it to the courtesy light, the link you have showed me seems a bit of a hassle is there an easier way to connect the wires of the addon directly within the door itself?
traffica1
PostPosted: Mon Sep 17, 2012 6:48 am Up
Or if possible to make them work only when i open the door, any idea of how to wire them to the door switch ?
Thank you for your support, its highly appreciated.
PostPosted: Mon Sep 17, 2012 8:14 am Up
As far as I know the central locking unit sends the signal to the BSI which in turn runs to the interior light.
You could try and locate the wire in the BSI unit to connect to, but I wouldn't try and connect to the wiring within the door in case it affects the operation of the locking motor.
Abzynthe
PostPosted: Mon Sep 17, 2012 8:17 am Up
East Area Rep - Abzynthe
Im sure Ste has done something similar. He probably wired it to the interior light. Its not too hard, just pop off the trim beside the windscreen and run the wires up there.
traffica1
PostPosted: Mon Sep 17, 2012 9:28 am Up
Thank you all for your support, i will try to wire it directly to the interior light.
All the best,
You've been highly supportive,
Thanks again
