Latest: Andyblue64
Overall: 17123
Online Now [212]:
Visitors: 211
Today: 24955
Total: 98028948
Forums › The Car › 206 Problems › 180 problem
180 problem
Boydie
PostPosted: Wed Sep 19, 2012 12:06 pm Up
noticed this this morning only happens when car is cold..just sounds as if it doesnt want to start then when it does start all the dash lights dim down and a consent bleep starts anyone no wats wrong?
s943.photobucket.com/a...76b91a.mp4
Gti 180
drunknmunky
PostPosted: Wed Sep 19, 2012 12:13 pm Up
it tells you whats wrong does it not? anti pollution fault? try getting the codes read....
Boydie
PostPosted: Wed Sep 19, 2012 12:25 pm Up
the anti pollution fault has been up for a while and this has came on all of a sudden
Gti 180
PostPosted: Wed Sep 19, 2012 1:22 pm Up
Battery
Lewis
PostPosted: Wed Sep 19, 2012 1:31 pm Up
I'm saying battery as well!
Tivoli LX 1.1
Black GTI 180
White VXR Burg
PostPosted: Wed Sep 19, 2012 2:00 pm Up
Check the fault codes first, get the battery tested or just check it with a good donor one to see if the fault goes
But from what i saw on the video doesnt look like a battery but from what you describe it does sound similar (if you didnt have the anti polution fault i would firstly suggest battery, but since you do....)
PostPosted: Wed Sep 19, 2012 2:10 pm Up
if it gives you a "Bongggg" sound,then that means your battery is weak,and need to be replaced ASAP,you will have more problems caused if the low voltage when you start your car.
nellyhaggis
PostPosted: Wed Sep 19, 2012 2:19 pm Up
Mine did this. Battery.
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
JamieM
PostPosted: Wed Sep 19, 2012 4:14 pm Up
I had that problem when my last car was mapped, turned out to be the maf sensor, it was either cleaned or replaced and all was well.
Aegean Blue 206 GTi180
PostPosted: Wed Sep 19, 2012 5:15 pm Up
Another vote for battery.
Parkerspug
PostPosted: Thu Sep 20, 2012 1:43 am Up
yep battery!! i lived with the beep for a month or so till one day it didnt start!
When you get a new battery go for a decent one, not a cheap one as it wont last!
Ryan
Schumi
PostPosted: Thu Sep 20, 2012 2:05 am Up
There is no MAF in Peugeot. Your problem could be MAP.
My bets on battery.
2005 206 RC RED
PostPosted: Thu Sep 20, 2012 6:28 am Up
Yes you need a new battery,buy a new 55 mAH,a decent one ,like VARTA,or Delfie,or Fiamm
JamieM
PostPosted: Thu Sep 20, 2012 6:38 am Up
My bets on battery.
Going by what I was told maybe it was o2 sensor it was like 7 years ago. It's not my current car.
It was definitely a sensor though and after it was cleaned it ran sweet.
Either way,
Battery causing the cut yeah and beeps yeah
Battery causing the anti pollution fault?
PostPosted: Thu Sep 20, 2012 6:52 am Up
JamieM wrote:
My bets on battery.
Either way,
It's french electrics, mysterious things that have no link between the two can happen.
