Latest: Makomeister18274
Overall: 17122
Online Now [44]:
Visitors: 43
Today: 26039
Total: 97805026
Forums › The Car › 206 Talk › Will this fit 2001 Gti?
bart84
PostPosted: Mon Oct 15, 2012 3:55 pm Up
www.vibra-technics.co....ew_engines
As mentioned, will this fit as looks identical and I'm sure its same dimension but engine code doesn't match to the 2 litre!
PostPosted: Mon Oct 15, 2012 3:59 pm Up
will fit.
bart84
PostPosted: Mon Oct 15, 2012 4:08 pm Up
Thanks for rapid response.
Now all I need is someone to sell me this engine mount if there's anybody on here breaking a motor?
PostPosted: Mon Oct 15, 2012 4:09 pm Up
what do you mean?
that mount is not oem mount. They are road/rally mount
bart84
PostPosted: Mon Oct 15, 2012 4:25 pm Up
Its a replacement bush that will require a press to fit, but I ideally require a spare metal bracket/mounting for a few quid so I can fit bush to this mounting whilst at work. Come weekend I'll remove my old one and fit with new replacement mounting in a straight swap.
All this with the intention of not keeping car off road for too long.
I know it says road/rally, but surely will be an upgrade for road use? My standard one at the movement knocks with every gear change
martinius88
PostPosted: Tue Oct 16, 2012 7:43 am Up
I had this and used it in my road car, was fine, will vibrate a little bit to start with but beds in soon enough.
206 2.0 GTi 138, Eibach: Pro-Kit, torsion bar adjusted, ULTRA angel eyes, Black Lexus rear lights, LED side indicators, Scorpion Cat back exhaust system, K&N Panel filter, theloudest.com speakers fitted all round, Sony HU.
Ibiza Cupra 1.8T 20V, JabbaSport Stage 2 Map, K03s Turbo, Forge 008 re-circ Dump Valve, N249/N111 bypass, H&R Lowering Springs, Forge FMIC. 225BHP @ 1.0 Bar. 0-60--5.6s, 1/4mile--14.2
My Old 206 GTi: www.206info.co.uk/Foru...39589.html
New Car - Ibiza Cupra: www.206info.co.uk/Foru...tml#530454
