Posted: Mon Sep 17, 2012 7:29 am |
Ive been searching all morning and can only find topics about locking 'bouncing' when used..
My problem, as usual, is slighly different to the norm..
Basically, my girlfriend has a 2002 206 LX, pre-facelift. Had it 3/4 months now and all has been fine apart from the last 3/4 weeks...
She has been complaining that the central locking wont work on the fob, only when using the key. I changed the battery at the begining but made no difference.
I got bored of her moaning so decided to take a proper look at it today, and here is the problem...
It intermitantly locks/unlocks on the button. It seems to lock/unlock around 5 times then stops for abit, then works again for abit then stops.
When it stops, i tried to lock the car via the key and it only locked the door i was locking, not all of them, as though the central locking wasnt working.
As said, i left it unlocked for 5mins came back and it worked.
I sat inside it and tried to lock/unlock, it didnt work. I held the fob upto the ignition barrell and tried to lock and it worked perfectly.
i tried to resync, i held the unlock button, put it in the ignition, turned ignition on n held for 10 seconds. Nothing happend. Tried again with the lock button, nothing happened.
This is the fob the car has:
Fob
Dont really know what to try now
Also, i replaced the fob casing (only the rubber button side) when i got the car as the rubber were split, dont know if that will have any affect. I removed the circuit board and tried again and it was the same.
Any helpers?
Posted: Mon Sep 17, 2012 9:37 am |
The BSI unit disables the central locking system for a short while after repeated 5 lock / unlock cycles to stop the locking motors from burning out.
Check the buttons on the pcb are not faulty / cracked or dry solder joints.
To resync the key on a multiplexed 206, start the engine then press & hold the lock button for 10 seconds.
Posted: Mon Sep 17, 2012 10:01 am |
ah rite.. been resyncing wrong then. wel, i assume its multiplexed, am i right in thinking that as its got the newer stalk unit that its multiplexed?
Posted: Mon Sep 17, 2012 10:03 am |
The keyfob gave the game away with the multiplexing.
Check the buttons on the pcb as they can break / fail with age / repeated use.
Posted: Mon Sep 17, 2012 11:10 am |
Pcb? Xcuse my ignorance im not down with all the 206 lingo im 306 man at heart
Posted: Mon Sep 17, 2012 11:29 am |
ct-xsi wrote: |
Pcb? Xcuse my ignorance im not down with all the 206 lingo im 306 man at heart |
Printed Circuit Board inside the keyfob.
The buttons soldered on to it can fail / the solder joints can also break.
Posted: Mon Sep 17, 2012 2:50 pm |
ah right cheers pal will check it out..
It seems to be like a loose connection or something with it being intermittent..
Posted: Mon Sep 17, 2012 5:07 pm |
Mine was the same, got a repair kit of eBay consisting of 2 new buttons, new blade and a new case for around £3.50 delivered.
After replacing both buttons (use a 15w soldering iron) and the case to make look new it works perfect now.
If you do the same remember to swap the transponder into the new case - i forgot and nearly had a heart attack when to car wouldn't start, i thought I'd screwed up the PCB when replacing switches lol. Soon realised what I'd done though
Posted: Mon Sep 17, 2012 7:55 pm |
Posted: Tue Sep 18, 2012 4:29 am |
MrBSI already answered that question, its just a printed circuit board.
Posted: Tue Sep 25, 2012 11:50 am |
had a look at them today, they all seem to be joined as they should.. is there an easy way to check it
