Latest: elelectricistadeMateo
Overall: 17127
Online Now [71]:
Visitors: 70
Today: 346
Total: 100398588
Forums › The Car › 206 Talk › How does an ECU detect specific cylinder misfire?
PostPosted: Thu Sep 27, 2012 9:49 pm Up
OK, if a spark is NOT happening that's easy, no current pulse at the line for that spark-plug.
(But they are also fired in pairs due to wasted-spark scheme..)
If a spark IS happening and an injector coil is NOT open-circuit what other means does the ECU have of detecting specific-cylinder misfire?
The O2 sensors are very slow response so I can't imagine them being of any use.
The knocking sensor (essentialy a mic) combined with crankshaft position sensor would also seem a bit far-fetched..
So how's it done? Evil or Very Mad
I searched on-line but I can't seem to find good info on this and it could be quite useful
to know in interpreting trouble-codes I think.
Cheers.
ramigojag
PostPosted: Fri Sep 28, 2012 1:20 am Up
The ecu knows how many teeth should pass through the crank sensor for each given firing stroke (as the piston is coming back down) if there's s misfire there is no force pushing the piston down therefore it would move much slower thus less teeth passing through the crank sensor in a given time.
The crank sensor will know which cylinder was firing because there is a notch or some kind of mark to represent TDC on no. 1 cylinder and can work out from this which cylinder was firing when the misfire was detected
That's essentially it but someone might be able to explain abit clearer
PostPosted: Fri Sep 28, 2012 3:59 am Up
If the crank position sensor is reading teeth as well as the notch, that makes sense
because it could be possible to detect a slow-down of the pulse train in between..
In fact I think the 'notch' is a missing-tooth, but could this way be accurate enough to assertain misfire at various RPM?
What about sudden changes due to loading of the engine by the gearbox, bumps on the road etc?
ramigojag
PostPosted: Fri Sep 28, 2012 4:16 am Up
Sometimes it's a missing tooth sometimes it's a small cut out load on the engine would also effect ignition timing, air flow and various other things so the ecu would understand but when there's an anomaly such as one piston slower than the rest it detects there's something wrong
PostPosted: Fri Sep 28, 2012 6:03 am Up
Alright, cheers for reply and any further info/thoughts are welcome.
PostPosted: Fri Sep 28, 2012 6:07 am Up
you should check this one out
www.google.com.hk/url?...J6mKZ6H9_Q
PostPosted: Fri Sep 28, 2012 6:16 am Up
Cheers John, that settles it then:
"No combustion of the fuel mixture in one engine cycle results in the decrease of the torque and
the crankshaft instantaneous rotational velocity value (fig. 1). Crankshaft position sensor CPS ..."
Wicked document that.
PostPosted: Fri Sep 28, 2012 1:45 pm Up
Very good link,well explained Smile
