Latest: Andyblue64
Overall: 17123
Online Now [343]:
Visitors: 342
Today: 13095
Total: 98100357
Forums › The Car › 206 Problems › Air Conditioning unit location
kyral210
PostPosted: Sat Sep 29, 2012 11:18 am Up
Is this the airr conditioning unit (to the offside of the radiator)? If not, then where is it?
Dillon
PostPosted: Sat Sep 29, 2012 11:38 am Up
Staff - Dillon
That looks like a condenser there should also be a compressor (pump running from the Aux belt) and also a heat exchange unit and a large amount of gubbins inside the cabin behind the dash. What's the problem with it?
kyral210
PostPosted: Sat Sep 29, 2012 11:47 am Up
I turn the AC button on and nothing happens even after driving for a while. I heard those refilling kits can solve the problem, but I need to find the nipple where I can fill the gas first...
DIY maintenance on my 206
Dillon
PostPosted: Sat Sep 29, 2012 11:55 am Up
Staff - Dillon
Don't bother refilling yourself, get it refilled and checked out at a garage, if you don't get the correct amount of PAG oil into it you will kill the compressor. Plus they will pressure test it as well you may have a leak in it. Have you done the basic checks? fuses, checked to see if the compressor come's on (dip in the idle revs when AC is activated)
PostPosted: Sat Sep 29, 2012 11:56 am Up
oh dear.....
Dillon
PostPosted: Sat Sep 29, 2012 11:58 am Up
Staff - Dillon
Seabook wrote:
oh dear.....
Hmm... I have to agree TBH 'where is the nipple for refilling' (Hint: you have taken a picture of it...)
PostPosted: Sat Sep 29, 2012 12:02 pm Up
Dillon wrote:
Seabook wrote:
oh dear.....
unless you got the complete kit already, otherwise you need quite a few bits and pieces to re-gas the system. you can't use bolt the compress R134a can to the system.....
and considering paying only as little as 30 quid could re-gas the system from a garage; i wouldn't bother to buy the kit.
PostPosted: Sat Sep 29, 2012 12:13 pm Up
Servicing and filling A/C is an art.
PostPosted: Sat Sep 29, 2012 12:15 pm Up
that's science Laughing
PostPosted: Sat Sep 29, 2012 3:13 pm Up
Science is an art too.. and so is engineering. Smile
(imho of course)
