Latest: Puggingalong
Overall: 17129
Online Now [414]:
Visitors: 413
Today: 36398
Total: 100705757
Forums › The Car › 206 Problems › car feels unstable turning left
twitch169
PostPosted: Thu Sep 27, 2012 2:46 pm Up
hi all i just been reading another post on here about top suspension mounts, well my car feel unstable mainly turning left my left tyre has worn on the outer edge but i had my tracking done and its still wearing it out so i no tracking is fine plus i had new drop links and track rod end so dont think its them,
there is also i clunking noise while car is not moving turn wheel from lock to lock it clonks or getting out off a car park space for exsample, so i thought would this top suspension mounts be making that noise and making the left tyre were and making it feel unstable thank you
peugeot 1.6 xs lowerd with black 15\" alloys custom chrome grill painted red dash and trim
twitch169
PostPosted: Thu Sep 27, 2012 3:33 pm Up
bump
Nat-T
PostPosted: Fri Sep 28, 2012 2:40 am Up
could be the ball joint on the wishbone, mine was when this happened!
Euro/Smoothed 2003 China Blue Verve
Rayvern Hydraulics
Schmidt 3-piece splits/Mercedes Wheels + custom adapters to 5x112
Lots of smoothed custom bodywork Wink
ramigojag
PostPosted: Fri Sep 28, 2012 7:00 am Up
As above or could be top mounts sounds like it either get under the car yourself and give everything a good test to see where the weak link is or take it into a garage so many things could make it clunk
Also once a tyre had started to wear badly it will be difficult to get it to stop
weeman
PostPosted: Fri Sep 28, 2012 3:31 pm Up
hi, you have any luck with your car? if not you could try having a look yourself, obv jack the car up and use an axle stand where possible. if you grab the wheel and shake it from side to side and top to bottom. this will show up play in the rack/track rod end/topmounts ect. if there is play you could get a friend to shake the wheel and you can have a look, feel various part for play etc to double check if you cant pinpoint it..to check the lower ball joint take the weight off the wheel and put it on tight lock and get a bar between the hub and balljoint to lever it down.this will show the play in the bj. if your not confident take it to a trusted garage.
hope this helps a bit
twitch169
PostPosted: Sat Sep 29, 2012 8:31 am Up
hi there thanks for the replys im gunna jack it up later today or tommro to have a look at top mounts and ball joints hope its a top mount really easy change then but still unsure at this point so i will post back when i have solved this one lol
