Posted: Tue Aug 07, 2012 9:44 am |
Hi all, had my 180 for a year and a half now and love it to bits.
Am getting a problem when starting it, sometimes nothing happens when I turn the key apart from a hopeful 'click' from the solenoid. It bumps first time, tried rocking it in gear to move the starter position and battery is fine.
First thought was 'brushes' so I went to investigate, starter motor is hidden away under the inlet manifold?? (should have expected that having owned a 205 gti!!)
Have checked battery strap resistances (both seem fine)
So to cut to my questions:
1) Is it possible to get at the starter without removing the inlet manifold?
2) Anyone experienced a similar problem and have any suggestions that I may of overlooked?
Thanks guys
| 206 Gti 180sp\r\nStill scares me | |
Posted: Tue Aug 07, 2012 11:01 am |
Most likely a starter motor problem. Or some times can happen if u try a start it up straight away wait for lights to go out my old one was quite touchy like that lol you haven't got my old one have you lol
| Image removed due to size
focus st 3 with pro alloy intercooler, 3" mongoose down pipe, 200 cell sports cat and mongoose cat back, collins bov, dreamscience dsci cold air intake,focus rs injectors,focus rs oil cooler,dreamscience dsci tuneing platform mod X map,focus rs clutch & flywheel, rs fuel pump, polly bushes in wish bones rear axal and suspension white line front and rear arb, eibach pro street s suspension. | |
Posted: Tue Aug 07, 2012 12:47 pm |
Lol, might be.. Only met the blokes wife but it had 46k on the clock when I bought it.
I've been waiting for dash lights to go off and fuel pump to stop :-/
Really just want to know if there is a way to get at the starter without removing quarter of the engine
Should have known I'd need to buy an entire set of wiring and a huge pot of Vaseline to smear all the connections (because as everyone knows it never rains in France so they don't plan for wet weather and the effects it has on a car!)
Posted: Tue Aug 07, 2012 1:56 pm |
I think u have to take the inlet manifold off to get to the starter it's a easy job just time consuming lol
Posted: Wed Aug 08, 2012 5:26 am |
Bummer..
Thanks mate
Posted: Thu Sep 27, 2012 7:39 pm |
Solved.
Dismantled, removed starter (a job which I can confirm require removal of inlet manifold of on 04 model at least!) and cleaned out quite a lot of worn magnet from said starter, which must have been jamming the starter in place untill bumped or jolted sufficiently.
I've lubricated it and refit.
Working sweet as a nut
Saved £300
