Latest: sparrowdclxvi
Overall: 17139
Online Now [99]:
Visitors: 98
Today: 32334
Total: 113272553
Forums › The Car › 206 Problems › Will GTI clocks fit a non GTI?
kippo2012
PostPosted: Wed Sep 26, 2012 2:35 pm Up
So 2 weeks after buying my 206 the speedo decided to stop working, but all the other clocks do, and a few of the bulbs around the dials have died as well. Took it in to the mechanic and he did the usual unplug and plug back in trick, speedo still doesn't work, and he put new bulbs in and they still don't light up...
I'm now looking around for a new speedo/clocks, but thought I might as well double check if GTI clocks fit in my LX? Can't be bothered to buy it only to find out it doesn't fit! Cheers Smile
anton1989
PostPosted: Wed Sep 26, 2012 2:48 pm Up
Trade Rating: +16
if your car is plexed then you need plexed speedo, same if its not plexed
i think the gti ones do but not sure? what the difference?
kippo2012
PostPosted: Wed Sep 26, 2012 2:54 pm Up
No idea if mine is plexed or not, it's a 2001 if that's any help? I know I need a 2 plug connection though
Not sure what the differences between the gti and non gti clocks are, but from what I've seen it's just the colour.
usher
PostPosted: Wed Sep 26, 2012 3:11 pm Up
yours is pre plex the gti has 2 plugs 1 yellow and one white, last time i tried to use dials form another car it blew a few fuses, all you can do is try really, all that will be different is the numbers and they might have different speedo range im not sure
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
kippo2012
PostPosted: Wed Sep 26, 2012 3:25 pm Up
Are gti's plexed then? All I know is that my mechanic said I need the ones with 2 plugs
usher
PostPosted: Wed Sep 26, 2012 4:09 pm Up
pre plex is before 2003ish and plexed is after
project thread WIP
garage
FAQ
206 gti firedance
HDI90
PostPosted: Wed Sep 26, 2012 4:17 pm Up
2001 can be plexed and pre plexed
GTI 180
kippo2012
PostPosted: Wed Sep 26, 2012 4:40 pm Up
Ah I'm confused. Hardly any of the ones on eBay say whether they're plexed or not, just whether they're one or two plug.. Think I'll just go for one that's come off a car the same year as mine, and hope it's the right one? Haha
Nic_206
PostPosted: Wed Sep 26, 2012 5:52 pm Up
Pre plex - 2 plugs
Plexed -1 plug
So with your mechanic saying 2as stated yours will be pre I've had fitted gti and RG clocks in mine and every worked correctly exept my mileage read out of course
Ford focus st3 daily driver
Team: Red 20v6
PostPosted: Thu Sep 27, 2012 2:43 pm Up
Right
As above Pre multiplex has two connectors, white and yellow
Multiplex has one (white iirc)
Check if yours has an oil gauge or not first, as not every 206 does
If your car is MULTIPLEX then get a speedo that reads lower than yours as your BSI will take the highest reading
Does your 206 have a fat radio stalk controller?
kippo2012
PostPosted: Fri Sep 28, 2012 12:03 pm Up
Nope, it doesn't have an oil gauge.
Do you mean the radio stalk on the steering wheel? I wouldn't say it's "fat", probably 1cm diameter
