Posted: Mon Oct 01, 2012 7:15 pm |
Hi,
Got the above but am experiencing some noises from the rear. I have hosed everything down with WD40, all the bushes seems to be intact and there is nothing loose I can jiggle around under there. The suspension feels fine and cornering is all good.
Any ideas what this could be? Hard I know but it sounds like squeaking/grinding. Does not happen all the time. Also could this be related with a crap action of the handbrake? I've adjusted it but still it is a bit poor. Any help is most useful!
Thanks.
Supa
| Everybody panic! Its just like the Titanic, but its full of bears! | |
Posted: Mon Oct 01, 2012 7:47 pm |
Checked the spare wheel cage?
Posted: Mon Oct 01, 2012 8:41 pm |
Yeah is tightened as tight as it will go.....
Posted: Tue Oct 02, 2012 4:16 am |
Is the anti roll bar end plate tight? They make a noise like you've described when they get a little bit loose. Just make sure you don't snap the bolt.
Posted: Tue Oct 02, 2012 9:40 am |
i have the same problem, I tightened up a bolt which made the noise dissapear, but for just a day and then it came back.
Posted: Tue Oct 02, 2012 9:48 am |
What kind of noise is it that is coming from the back . I had the same problem with a noise from the rear of the car and it turned out to be the rear axle bearing that had gone ?
