Latest: heikkisj
Overall: 17126
Online Now [45]:
Visitors: 44
Today: 1133
Total: 100334182
Forums › The Car › 206 Talk › Wheel refurb
Wheel refurb
bart84
PostPosted: Mon Oct 01, 2012 5:26 am Up
I've recently purchased a set of vortex with the intention to respray and refurb.
Just after a bit of advice, do I send them to the Bodyshop and let them take care of it OR do I get them powder coated before hand?
What's the benefit of powder coating pre painting?
Cheers
djdan0123
PostPosted: Mon Oct 01, 2012 6:00 am Up
I'd personally depending how bad they are if their ok either DIY or send to body shop normally £50 per wheel, that way they can use all their own stuff, I've had mine shot blasted as they were flaking and curbed and their near mint just waiting for paint, hope this helps?
Build your own dreams, or someone will hire you to build theirs.
Life's a gamble, Take your chances.
PostPosted: Mon Oct 01, 2012 6:25 am Up
Get them refurded & powder coated in the colour you want.
Matt
PostPosted: Mon Oct 01, 2012 6:43 am Up
Trade Rating: +32
Pm a member on here called Dave. He lives in Manchester and can do it for you cheaper.
bart84
PostPosted: Tue Oct 02, 2012 2:55 pm Up
Have been quoted mates rate at £40 per wheel including full prep and paint from a reputable body shop.
(considering my girlfriend paid £45 per wheel to sort out kerb damage I think this is a decent price)
My NEXT dilemma is tyre size!
I can purchase 205/40's around £10 less than 205/45's. I require 4 so it's quite a bit of dollar to save overall.
Will these elastic band walls provide too harsh a ride??
Andrew
PostPosted: Tue Oct 02, 2012 3:28 pm Up
I've had good work done by City Powdercoaters in Birmingham, but if that's too far I'd try Dave who is near you though, being as he does it on his own he takes his time to do good work and make a good name for himself.
Standard tyre for 17" wheels to provide a more accurate speedo reading are 205/40
My 206 thread
www.detailedbyandrew.com
138Andy
PostPosted: Tue Oct 02, 2012 6:19 pm Up
What He Said
citypowdercoaters did mine Smile looked sweet until some c*** at work took it for a spin and kerbed one
RedHDI
PostPosted: Sun Oct 07, 2012 10:31 am Up
Plastidip over them in what ever colour you want. It's cheap, easy to do and if you dont like it just peel it off. It's good for spraying over stratches and rubs. Its also a matte colour
thatplace
PostPosted: Sun Oct 07, 2012 10:55 am Up
you don't get wheels powder coated to then be painted
you either get them powder coated or painted
bart84
PostPosted: Thu Oct 11, 2012 7:40 am Up
The company who can powder coat my wheels have informed me they don't have a bead blaster to prep wheels.
There's nowhere that local who I can go to. Would sand blasting it be too harsh?
thatplace
PostPosted: Thu Oct 11, 2012 9:25 am Up
yes sand blasting is too harsh and can leave pits in the wheels
User Suspended
djdan0123
PostPosted: Thu Oct 11, 2012 10:15 am Up
Sand blasting is better then shot blasting I had mine shot blasted they've had 6 coats of paint still need another 2 atleast to hide the pitting, sand blasting should be find aslong as they've been sanded after
o050cal0o
PostPosted: Tue Oct 16, 2012 3:31 pm Up
Sand blasting is not too harsh if it's done right. I'm a painter and sandblaster. Check out my wheels that I did they where blasted before I painted them. You have to sand them down a bit after to take the rough edges off but it's only 5 min a wheel job its not massive. coat of etch primer, coat of high build primer flat that down then a paint coat then some laquer and you won't tell the difference. If anything blasting gives the wheel a better key so it's less likely for the paint to peel.
I have done loads of wheels this way. Over the summer I have lost count of the amount of motorbike wheels I have done this way including my own.
Powder coating is better then paint as its a lot tougher. Wish we had powder coating equipment at work as I would have done mine this way.
Peugeot 206 GTI180
