Latest: heikkisj
Overall: 17126
Online Now [51]:
Visitors: 50
Today: 18480
Total: 100391177
Forums › The Car › 206 Talk › What and where to buy a timing belt kit.
o050cal0o
PostPosted: Tue Oct 16, 2012 3:08 pm Up
Hi,
A friend of a friend works at Perrys (local main Peugeot dealers) and he has said he will fit me a timing bet to my gti 180 for £100 but he said get the parts as getting them from the dealers works out more expensive.
So my question is what brand do I go for and where's the best place to get them from.
Thanks.
Peugeot 206 GTI180
PostPosted: Tue Oct 16, 2012 3:10 pm Up
EuroCarPArts? Often do a discount code too on the website.
richpowell91
PostPosted: Tue Oct 16, 2012 3:12 pm Up
Gates
Dayco
Continential
Try your local motor factors and see what makes they supply, otherwise try somewhere like eurocarparts etc.
gazza82
PostPosted: Tue Oct 16, 2012 4:07 pm Up
Try buypartsby.co.uk .. I got a contibelt kit from them
PostPosted: Tue Oct 16, 2012 6:37 pm Up
SKF from eBay.
djdan0123
PostPosted: Wed Oct 17, 2012 1:54 am Up
Eurocarparts.co.uk or try central auto supplies
Build your own dreams, or someone will hire you to build theirs.
Life's a gamble, Take your chances.
usher
PostPosted: Wed Oct 17, 2012 2:07 am Up
unipart do the gates belts but re branded
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
