Latest: lio94
Overall: 17181
Online Now [212]:
Visitors: 211
Today: 83189
Total: 141837738
Forums › The Car › 206 Problems › Gti 140 noises from rear axel
Supacool1
PostPosted: Mon Oct 01, 2012 7:15 pm Up
Hi,
Got the above but am experiencing some noises from the rear. I have hosed everything down with WD40, all the bushes seems to be intact and there is nothing loose I can jiggle around under there. The suspension feels fine and cornering is all good.
Any ideas what this could be? Hard I know but it sounds like squeaking/grinding. Does not happen all the time. Also could this be related with a crap action of the handbrake? I've adjusted it but still it is a bit poor. Any help is most useful!
Thanks.
Supa Cool
Everybody panic! Its just like the Titanic, but its full of bears!
PostPosted: Mon Oct 01, 2012 7:47 pm Up
Checked the spare wheel cage?
Supacool1
PostPosted: Mon Oct 01, 2012 8:41 pm Up
Yeah is tightened as tight as it will go.....
DanT
PostPosted: Tue Oct 02, 2012 4:16 am Up
Is the anti roll bar end plate tight? They make a noise like you've described when they get a little bit loose. Just make sure you don't snap the bolt.
gdon
PostPosted: Tue Oct 02, 2012 9:40 am Up
i have the same problem, I tightened up a bolt which made the noise dissapear, but for just a day and then it came back.
hooliganchild46
PostPosted: Tue Oct 02, 2012 9:48 am Up
What kind of noise is it that is coming from the back . I had the same problem with a noise from the rear of the car and it turned out to be the rear axle bearing that had gone ?
