Latest: lio94
Overall: 17181
Online Now [322]:
Visitors: 321
Today: 1062
Total: 141755970
Forums › The Car › 206 Problems › Simple Fuse problem (I think) though need help
Stanton
PostPosted: Wed Oct 03, 2012 11:23 am Up
Hi all,
Currently have the drivers side dipped headlight bulb not working and also the left hand side rear light doesn't work on dipped, but does come on when I brake. The rear lights are multiple LED's and as they come on when breaking I would assume that must be a simple fuse blown rather than the LED's blown. The front right hand side intermittently decides to work so that might be a connection issue rather than a fuse, though hasn't come on for a while so I may as well check it.
According to the Haynes manual, these fuses should be F32 and F34, I believe. It is a 52 plate 2.0 HDI with automatic rain and light sensors which leads me to think it is multiplexed if that makes a difference. The fuse box I have under the steering wheel looks like this www.bradgatemotors.co....84.jpg.jpg however I cannot seem to locate the fuse numbers listed in the manual.
Any help will be massively appreciated,
Cheers,
Stanton
PostPosted: Wed Oct 03, 2012 11:26 am Up
Car is multiplexed & your using a NON multiplex fuse list.
Try looking at the correct fuse list for the electrical system fitted to your car.
www.206info.co.uk/Foru...t=108.html
Stanton
PostPosted: Wed Oct 03, 2012 11:30 am Up
Ahh thanks, knew I was being an idiot somehow.
Stanton
China Blue 2.0 HDI
Stanton
PostPosted: Wed Oct 03, 2012 11:35 am Up
Actually, one last thing please. Can't find the rear normal light (not braking) on that list.. Feel free to patronise my stupidity on this one
Stanton
China Blue 2.0 HDI
Stanton
PostPosted: Thu Oct 04, 2012 1:09 pm Up
Bump
Stanton
China Blue 2.0 HDI
Stanton
PostPosted: Fri Oct 05, 2012 7:06 am Up
Bump..
Stanton
China Blue 2.0 HDI
