Latest: dreyfalon
Overall: 17121
Online Now [72]:
Visitors: 71
Today: 9378
Total: 97757376
Forums › The Car › 206 Talk › Engine mounts where to find
Danielpates
PostPosted: Thu Oct 11, 2012 2:43 pm Up
I have a gti 180 with a bad clutch judders but have noticed in between changing gear I get a really bad pull as if the engine mounts are moving to much.does anybody know where to get some uprated ones from but are not to harsh ie to solid
PostPosted: Thu Oct 11, 2012 4:20 pm Up
doesn't exist
uprate engine mount will vibrate your teeth of from your mouth.
PostPosted: Thu Oct 11, 2012 4:39 pm Up
Even using Vibrta Technics road mounts refinement take a big drop.
