Latest: dreyfalon
Overall: 17121
Online Now [564]:
Visitors: 563
Today: 62276
Total: 97588576
Forums › The Car › 206 Problems › Problem Installing SP Pedals To HDi
Jaeger
PostPosted: Mon Oct 08, 2012 4:33 am Up
I am trying to install GTi (SP) pedals.
I have HDi standard ones so I will have to drill holes.
But I cannot get all the way to the back (last hole).
Is it possible to remove the pedals (complete arm) and drill it in a vise and put it back?
And will it take long?
Also will a GTi gas pedal arm fit an HDi?
The clutch and brake look easy to do but the gas looks tricky, if I can replace with GTi then I will do that.
2001 Peugeot 206 2.0 HDi 90 D TURBO in China Blue (98-01) [57 MPG]
Jaeger
PostPosted: Mon Oct 08, 2012 8:11 am Up
Anyone?? Crying or Very sad
shell-vt
PostPosted: Mon Oct 08, 2012 9:50 am Up
Trade Rating: +46
hi im sure there is a guide to this if you search
york 16,3
PostPosted: Mon Oct 08, 2012 10:07 am Up
looks like i got different pedal as yours, i can unclip my standard pedal off the arm
MPorter13
PostPosted: Sun Oct 14, 2012 7:03 am Up
I just drilled mine, took a few minutes, used masonary bits and it went through reasonably quick
MPorter
pug206lx
PostPosted: Sun Oct 14, 2012 8:12 am Up
When i did mine years ago i bent the top of the pedal so i could get the drill onto it.
SteDuval1985
PostPosted: Sun Oct 14, 2012 1:52 pm Up
I removed the rubbers, and used this to attach the SP pedals to the standard ones...
www.ebay.co.uk/itm/Sho...3a79050ff7
...no drilling required, just applied to some of that to each SP pedal and held it in place for 5 mins (enough time for the goo to set in) and they've been on for the last 18 months with no problems.
PostPosted: Sun Oct 14, 2012 2:58 pm Up
MPorter13 wrote:
used masonary bits
Bodger.
Rob2859
PostPosted: Sun Oct 14, 2012 7:08 pm Up
Tiger Seal...
