Online Now [369]:
Visitors: 368
Today: 25584
Total: 142839084
Forums › The Car › 206 Problems › Brake line spanner size
shaun88
PostPosted: Thu Oct 11, 2012 3:28 pm Up
Ok, so this is annoying, i bought a set of brake spanners as im removing some of my brake pipes. Problem is 10mm is to small 11mm is to big, what other options are there?? someone said a 7/16 but im a bit out of touch with sizes does this sound like it would do the job its literally like i need a 10.5mm spanner???
Thanks guys and girls...
if it aint broke, don't fix it... when it breaks, hit it with a hammer...
Gavin28
PostPosted: Thu Oct 11, 2012 3:48 pm Up
a 7/16 is about 11.1mm so wont help but they both usually work
heres a chart i just found www.csgnetwork.com/wre...table.html
Edit: If your replacing the parts anyway just use vice-grips
Gav
shaun88
PostPosted: Thu Oct 11, 2012 3:53 pm Up
Mole grips it is then lol. Just going to be a pig getting round the rear axle and lav. Bloody cars. Thanks
PostPosted: Thu Oct 11, 2012 4:40 pm Up
Don't use mole grips on anything that's going to be re-used though.
PostPosted: Thu Oct 11, 2012 4:45 pm Up
i would be surprise you can take it off with mole grip.
get a proper brake line spanner
shaun88
PostPosted: Thu Oct 11, 2012 4:47 pm Up
not going to take anything off that needs reusing, mole grips destroy anything they come in cntact with, and seabook i have but cant get none to fit as i explained??
thanks shaun
PostPosted: Thu Oct 11, 2012 4:57 pm Up
i am fairly sure it is 11mm size as i did mine not long ago.
unless someone round off some of the nut before....
might be better grind it off
shaun88
PostPosted: Thu Oct 11, 2012 4:59 pm Up
will try 11 again tomorrow but fairly sure it didnt fit i tried 3 different unions, if i grind it off i wont be able to remove the thread from master cylinder lav or drums???
PostPosted: Thu Oct 11, 2012 5:01 pm Up
it would be hard....
or use adjustable spanner? Laughing
shaun88
PostPosted: Thu Oct 11, 2012 5:02 pm Up
will have a go tomorrow when it eventually stops P*****g down!! will post and let you know how i got on,
cheers
PostPosted: Fri Oct 12, 2012 2:53 am Up
Thats what happens with a lot of diy brake pipe jobs Wink
gazza82
PostPosted: Fri Oct 12, 2012 9:22 am Up
It might be better to try and fit something down the side of the nut and spanner to take up the space. It it does slip it will just round it off more ...
And take care as if you turn the whole pipe it will bend or worse, snap off
shaun88
PostPosted: Fri Oct 12, 2012 9:51 am Up
That sounds a good idea, im renewing all brake lines and joints anyhow so if worse comes to worst and they snap i am renewing anyway!!
Regards
Shaun
richpowell91
PostPosted: Fri Oct 12, 2012 1:12 pm Up
Just cut the brake pipe before the union, that way you will be able to get a socket on it to undo it before its completely rounded.
SinfulDesignCom
PostPosted: Fri Oct 12, 2012 2:37 pm Up
the 10mm will fit - it will just need a bit of encouragement. If it really won't, take a very fine file to the nut until it does fit...
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
