Online Now [718]:
Visitors: 718
Today: 130689
Total: 145813994
Forums › The Car › Request a how-to › Oil Pressure Switch change, 1.4l 8v, 2004.
seagull104
PostPosted: Wed Apr 28, 2021 2:31 pm Reply with quote Up
I have just completed a cylinder head gasket change on a 206LS, 1.4l 2004 8v TU3JP and now find the oil pressure switch is leaking. How can I find out which switch is the correct one? There are at least 3 variables so how do I ensure I order the correct item?
I phoned Autolec who quoted me £8.38 incl. VAT, 6 miles away. Now fitted and all looks good again. I removed the leaking switch eventually with a 22mm ring spanner to ensure I bought the correct item. Unfortunately the switch loosened suddenly on high torque with the result that I have broken off part of the metal shroud around the switch. I hope it's not too important. The switch part number was CAMVE706058, grey square connector.
  Quick Reply
Username:
Message:
Quote the last message
