Latest: heikkisj
Overall: 17126
Online Now [77]:
Visitors: 76
Today: 15655
Total: 100388367
Forums › The Car › 206 Problems › Gti 180 feels like its bucking
Danielpates
PostPosted: Tue Oct 16, 2012 3:31 pm Up
Edited thread now. Basically when driving normal at a steady speed and the revs stay the same it feels like the engine is pullsing but when i accelerate it doesn't happen.feels like the car is bucking
jayz206gti
PostPosted: Tue Oct 16, 2012 5:07 pm Up
You lost me half way through your explanation dude
Upgraded from 138 to 180
JamieM
PostPosted: Wed Oct 17, 2012 2:22 am Up
Don't know but it sounds like you bought one that needed all the common things doing at once.
If I were you I'd get the belt changed while you're at it. They ALL should have been changed at least once by now.
Aegean Blue 206 GTi180
Big_Rich180
PostPosted: Wed Oct 17, 2012 3:10 am Up
Get a diagnostic done then go from there.
nellyhaggis
PostPosted: Wed Oct 17, 2012 4:20 am Up
I feel your pain.
They are great to look at and drive but a nightmare to maintain and fuel!
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
nellyhaggis
PostPosted: Wed Oct 17, 2012 4:43 am Up
I feel your pain.
Danielpates
PostPosted: Wed Oct 17, 2012 5:09 am Up
have had it plugged in and no codes
nellyhaggis
PostPosted: Wed Oct 17, 2012 6:15 am Up
Might be a long shot but the fuel filter on the pump might need cleaned out!
PostPosted: Wed Oct 17, 2012 6:22 am Up
Such behavior from engines is often caused by air leaks.
Danielpates
PostPosted: Wed Oct 17, 2012 10:21 am Up
Air leaks ok then.what do I need to check for
Danielpates
PostPosted: Wed Oct 17, 2012 2:53 pm Up
anybody
anton1989
PostPosted: Wed Oct 17, 2012 3:23 pm Up
Trade Rating: +16
the answer to this question is at the start of the question Wink
jokes aside have you took it to a garage yet? what did they say?
Danielpates
PostPosted: Thu Oct 18, 2012 5:16 am Up
no i havent tbh.want to try and do it myself cant afford garage prices plus thy lead you down the garden path saying its this and that and could be something completely different and then end up spending loads of money and still doesnt get sorted.had this happen before
Danielpates
PostPosted: Thu Oct 18, 2012 1:15 pm Up
if the coil pack was breaking down it would do it all the while wudnt it
Gavin28
PostPosted: Thu Oct 18, 2012 4:32 pm Up
i had this in my old 306 diesel - turned out to be engine mounts
Gav
