Posted: Tue Oct 16, 2012 3:08 pm |
Hi,
A friend of a friend works at Perrys (local main Peugeot dealers) and he has said he will fit me a timing bet to my gti 180 for £100 but he said get the parts as getting them from the dealers works out more expensive.
So my question is what brand do I go for and where's the best place to get them from.
Thanks.
Posted: Tue Oct 16, 2012 3:10 pm |
EuroCarPArts? Often do a discount code too on the website.
Posted: Tue Oct 16, 2012 3:12 pm |
Gates
Dayco
Continential
Try your local motor factors and see what makes they supply, otherwise try somewhere like eurocarparts etc.
Posted: Tue Oct 16, 2012 4:07 pm |
Try buypartsby.co.uk .. I got a contibelt kit from them
Posted: Tue Oct 16, 2012 6:37 pm |
SKF from eBay.
Posted: Wed Oct 17, 2012 1:54 am |
Eurocarparts.co.uk or try central auto supplies
| Build your own dreams, or someone will hire you to build theirs.
Life's a gamble, Take your chances. | |
Posted: Wed Oct 17, 2012 2:07 am |
unipart do the gates belts but re branded
