Posted: Sat Oct 13, 2012 1:41 am |
hey as above im wanting to paint most of my car on the inside like door handles sterio face ect but im having a problem knowing how to take the air vents out i dont want to take them out and brake clips ect and also would i need to sand down these parts or just spray strait over ????? if anyone can give me some advice it would really really help
Posted: Sat Oct 13, 2012 2:36 am |
use the search bar bud too many helpful threads to mention
| PEOPLE ARE TOO SERIOUS
My car: 1.4 Lx 2002 silver. With only 25,700 miles and completely standard ...... AT THE MOMENT ANYWAYS
Prog Thread: www.206info.co.uk/Foru...42301.html | |
Posted: Tue Oct 16, 2012 3:14 pm |
You don't need to sand plastic. Just get them out of the car then get some scotchbrite that rough stuff on the back of washing up sponges give them a rub down with that to give it a "key" you want to put loads of little scratches on it to give the paint something to stick to. You dont need to go mad just loose the shiny finish.
Posted: Thu Oct 18, 2012 4:57 pm |
make sure to use plastic primer otherwise it will just peal off.
And its a Peugeot so just pull it and its sure to come off.
Posted: Thu Oct 18, 2012 5:55 pm |
14hdi wrote: |
And its a Peugeot so just pull it and its sure to snap off. |
Posted: Fri Oct 19, 2012 8:27 am |
very true.
I took my vents out the other day, point them down and then just pull and they pop off. But thats the vent not the trim around it. That just needs a thin blade or screw driver behind it and it pops out. Its held in by little metal clips.
