Posted: Sat Oct 20, 2012 10:08 am |
Hi folks,
Sorry one of my first posts is requesting help
Recently picked up a 2000 206gti for using over the winter instead of the bike.
Trouble is,the power steering pipes have rusted through an I can't get any as they are no longer made.
Can anyone tell me if ones off any other models fit?
Or is anyone breaking one and have a set to of pipes to sell?
Baz
Posted: Sat Oct 20, 2012 10:21 am |
Did the Peugeot dealer say they can't get them?
Are these the pipes near the steering rack? Pirtek might be able to make something...they can certainly do the hoses so might be able to fabricate the metal pipes too.
Posted: Sat Oct 20, 2012 10:28 am |
Thanks mate,I've been told from them that the parts have been discontinued
I've been thinking about pirtek as I work not far from one of their places.
It was the fittings on the end of the pipe work that looks like it may cause problems.
Posted: Sat Oct 20, 2012 10:30 am |
Posted: Sat Oct 20, 2012 10:41 am |
So is it where the pipes fit into the rack? Reason I ask is I've got a freshly removed PAS pipe that sits behind the front bumper ...but I don't think it's that bit you need.
Thanks mate,greatly appreciated.
I've dropped him a pm for now
Posted: Sat Oct 20, 2012 11:04 am |
| Edward wrote: |
| Pirtek might be able to make something...they can certainly do the hoses so might be able to fabricate the metal pipes too. |
Pirtek can easily fabricate the metal pipes to
Posted: Sat Oct 20, 2012 11:07 am |
| Edward wrote: |
| So is it where the pipes fit into the rack? Reason I ask is I've got a freshly removed PAS pipe that sits behind the front bumper ...but I don't think it's that bit you need. |
It's at the rack it's leaking but when I got them taken off they run all the way to the pump up front.
Never realised they were in sections.
Posted: Sat Oct 20, 2012 11:08 am |
| MrBSI wrote: |
| Edward wrote: |
Pirtek can easily fabricate the metal pipes to  |
Ideal,that's what I like to hear
Be round there Monday mornin
Posted: Sat Oct 20, 2012 11:10 am |
Oh,and does anyone know if the blue plug half way down one of the pipes is important please ?
Posted: Sat Oct 20, 2012 11:16 am |
| Baz.rsv wrote: |
| Oh,and does anyone know if the blue plug half way down one of the pipes is important please ? |
Thats the power steering pressure switch for the engine ecu.
Its best if the old pipework is removed so Pirtek can use it as a pattern.
Posted: Sat Oct 20, 2012 11:31 am |
Magic,I'll just take em in whole .
