Latest: Kifi69
Overall: 17183
Online Now [444]:
Visitors: 443
Today: 114555
Total: 144132392
Forums › The Car › 206 Problems › Strange handling issues
Rob2859
PostPosted: Sat Feb 19, 2011 12:56 pm Up
I have had this problem for a long time now but it is getting worse. Its not very simple.
Symptoms:
Going over a poor road surface the car skips and is upset more than it used to be by bumps especially when accelerating.
At higher speeds (50mph+) The car tends to pull randomly to ether side. Like I have yanked the wheel or been hit by a big gust of wind. This makes motorway driving feel quite unstable. This also happens when cornering. It is coming to the point where I could be cornering at speed and it could potentialy cause me to loose the back end.
Yes it could be a number of things but I have ruled out a numper of them.
Tracking
Tyre pressure
Balancing
Wheel buckling
Also there is no play in the wheels; that rules out things like track rods, trailing arms and wishbone bushes.
That left me with 2 ideas; Drop links and Shockers. The drop links however would make a noise if work like a banging or clunking. It doesn't seem to be the shocks ether becase if you push the car up and down the shocks seem to rebound fine.
I have spoken to a number of mechanics and they don't know ether.
PostPosted: Sat Feb 19, 2011 1:35 pm Up
have you check the spring?
it might have broken or came off from the cap.
Rob2859
PostPosted: Sat Feb 19, 2011 1:48 pm Up
that is a point. Although they look fine and it sits level
stevedude
PostPosted: Sat Feb 19, 2011 4:46 pm Up
could it be rear axle?
ive heard if they go the cars all over the place
Happydays
Rob2859
PostPosted: Sat Feb 19, 2011 8:05 pm Up
that seems fine. The shocker on one side has started squeeking though thought it was the brakes. It feels fine though
chrisd
PostPosted: Sat Feb 19, 2011 9:28 pm Up
Its the wishbone or topmount, trust me had this probably and didnt notice it was a wishbone til i had new/old part side by side
PostPosted: Sun Feb 20, 2011 4:07 am Up
Check wheel bearings some point, made my handling naff on mine ,
SarahW
PostPosted: Sun Feb 20, 2011 1:19 pm Up
I'm having the exact same issue with mine, it seems to be since i got my tracking donw though, took it back and it got done again and it improved slightly, mine is the same it does it at high speeds it pulls to the right suddenly and when i go around a roundabout at normal speed too, it doesnt do it however when i turning right at a junction for instance or turning left, just tends to be roundabouts and high speeds.
SW.
stevedude
PostPosted: Sun Feb 20, 2011 1:25 pm Up
ill let ya know tomoz as ive just changed my wishbone
Happydays
Rob2859
PostPosted: Sun Feb 20, 2011 1:30 pm Up
I have two fairly new wishbones, should be less than 6 months old I think. How can I tell visually when looking at the top mounts.
PostPosted: Sun Feb 20, 2011 4:02 pm Up
no you can't tell just by looking at it.
if the topmount bearing fail you will hearing knocking noise when you turn your steering wheel.
Rob2859
PostPosted: Sun Feb 20, 2011 8:07 pm Up
don't have that so its not them
stevedude
PostPosted: Mon Feb 21, 2011 11:04 am Up
well shes alot better ride today, but tracking is out now, gonna do other wishbone on sat, then get tracking re done.
one problem thou, i now get one huge bang when i start car, i think it might be mount, but god knows which one, how can i tell? and where are they?
Happydays
lewisbow123
PostPosted: Sat Sep 15, 2012 8:46 am Up
please help I Have this exact thing you explained it exactly how I have its more when steering left and at higher speeds it's like the steering has a mind of its own .. it started when I put alloys on drove it home and it was fine .. took it to be tracked and this stuff started .. I took it back and told them and they found that one of my alloys was loose .. don't no how but it was .. anyway they said that wad what the problem was .. anyway all the alloys are perfectly fine but it's still doing this and the tracking place hasn't really Done anything to make it better they just keep 're tracking it but it's still just as bad .. I don't no what to do because I can't even describe it and it's dangerous to drive in my opinion it's like I'm fighting the steering !!! I don't have much of a clue what to check my self!
Rob2859
PostPosted: Sat Sep 15, 2012 6:19 pm Up
Probably the wishbone ball joins have play in your case. When you fit wider tyres the wondering in the steering is more noticeable. Had this issue twice before.
