Latest: eltel666
Overall: 17146
Online Now [85]:
Visitors: 84
Today: 46539
Total: 116183462
Forums › The Car › 206 Problems › missfire
missfire
thompson69
PostPosted: Wed Apr 20, 2011 6:51 am Up
hi i have a 1.6 glx and it is missing. its not the coilpack or the plugs. but it only missfires when the ligth comes. then it gose off after its missfired hope u can tell wht i mean. thanks ray
1999 1.6 v8 ripspeed front door speckers, jbl back door speskers, vibe slick 6x9s. gti steering wheel, momo gear knob, debadged, after market bonnet vents, m3 mirrors with leds and info sticker
MrrNoName
PostPosted: Wed Apr 20, 2011 6:53 am Up
if the lights come on a code will be stored, get it code read? that will point you to what it is if your sure its not the coil pack or plugs, make sure that you havnt used NGK plugs because they are notorious for causing missfires apparently..
thompson69
PostPosted: Wed Apr 20, 2011 6:58 am Up
iv used bosch
MrrNoName
PostPosted: Wed Apr 20, 2011 7:23 am Up
do you know which cylinder is missfiring? you could try swapping the plugs and see if its moves to another cylinder. if not its probs best to get it code read tbh
PostPosted: Wed Apr 20, 2011 7:30 am Up
faulty injectors? even the harness possibly.
thompson69
PostPosted: Thu Apr 21, 2011 2:36 am Up
can I check them? If so how?
PostPosted: Thu Apr 21, 2011 4:57 am Up
i think you can test the voltage across each of them with a multimeter.
thompson69
PostPosted: Thu Apr 21, 2011 9:17 am Up
what you mean?
PostPosted: Thu Apr 21, 2011 9:39 am Up
thompson69
PostPosted: Thu Apr 21, 2011 9:41 am Up
thanks lee
punk
PostPosted: Thu Apr 21, 2011 11:36 am Up
I think i need to do this on Injector one....Find out it someone is fibbing. Cheers Lee
cully11
PostPosted: Fri Feb 01, 2013 12:28 pm Up
hi my 1.4 glx was misfiring & shaking i put new fuel rail & injectors on
no more misfire & shaking now running like a new car see if it works for you best of luck
