Online Now [354]:
Visitors: 353
Today: 77713
Total: 105406149
Forums › The Car › Solved 206 Problems › Changed speakers. Engine Management Light now.
guvna
PostPosted: Fri Oct 26, 2012 7:44 am Up
As title says.
Changed the speakers from factory fitted to brand spankers, and 2 days later the Engine Management Light has come on.
As the original wiring that hooked into the factory speakers had a special plug on the end of them, I had to order up a set of adaptor cables so I could plug the new speakers in. They work fine. No problems. No shorting that I can see as everything is contained in the plastic surround in the door, so can't imagine they're grounding out on anything.
Does the speaker loom get back to the ECU at all that would cause this light to come on, or just co-incidence?
Thanks.
Guv.
Big_Rich180
PostPosted: Fri Oct 26, 2012 7:57 am Up
Its a Peugeot..its probably nothing to do with the wiring.
Try getting the codes read, there's probably tonnes of codes stored on the ECU.
PostPosted: Fri Oct 26, 2012 10:40 am Up
Surely a coincidence? Never heard of this before Confused
anton1989
PostPosted: Fri Oct 26, 2012 11:14 am Up
Trade Rating: +16
it wont be the speakers.
go to a garage and have the codes read, that will pointto where abouts your problem is, simple as that Wink
also how come this is in solved?
