Posted: Sat Sep 15, 2012 7:21 am |
Trade Rating: +16
ok so had a few problems with my old car
CLICK HERE
found it to be the 4th injector
i can get the injector of another 206 that is being broken near me
my question is; are all the injectors the same? what i mean is, is injector 1 the same as 4? so if i took injector 1 from the other car to replace injector 4 on mine will it work?
thanks
Posted: Sat Sep 15, 2012 8:45 am |
Trade Rating: +16
the garage aid injector 4 but i put the code in a website and it said cylinder 3? does this mean it injector 3?
CLICK HERE
Posted: Sat Sep 15, 2012 11:32 am |
you can swap the position of the injector
Posted: Sat Sep 15, 2012 1:44 pm |
If the garage were just going off the code, I would assume they got it wrong
Posted: Sat Sep 15, 2012 1:51 pm |
I'm sure I've heard injector fault codes can actually be crank sensor faults.
Posted: Sat Sep 15, 2012 4:16 pm |
Trade Rating: +16
Harry wrote: |
If the garage were just going off the code, I would assume they got it wrong |
so should i change the 3rd one?
Seabook wrote: |
you can swap the position of the injector |
thanks seabook, see how i posted in the correct section
Posted: Sat Sep 15, 2012 4:17 pm |
Trade Rating: +16
Edward wrote: |
I'm sure I've heard injector fault codes can actually be crank sensor faults. |
it runs like s**t, could this still be crank sensor?
Posted: Sat Sep 15, 2012 4:22 pm |
It could be. I'd change it to be on the safe side.
Second hand injectors could be just as bad as yours. You'll be better off buying a new set.
Posted: Sat Sep 15, 2012 4:56 pm |
Trade Rating: +16
where is the crank sensor? is it a d.i.y job to replace? how much will it cost? i dont want to spend to much on the car as its being sold its already cost me £200 to put right inc m.o.t
Posted: Sat Sep 15, 2012 6:36 pm |
i doubt crank sensor would cause it run like s***
it should be easy to find out which cylinder is missing and work from there, swap plug and injectors to isolated the problem before buying any parts!
Posted: Sun Sep 16, 2012 5:02 am |
Trade Rating: +16
ok will be looking at this later, swap plug? can i change the plug on each injector? thought all 4 were on one part?
Posted: Sun Sep 16, 2012 6:05 am |
Right
First off has the injector fault code gone? As Injector four is the one closest to the cambelt (french did the order backwards to the norm) and NOT the one closest to the gearbox, that is number one
Before changing it, move that injector to the one along and see if the fault code moves, if it does, then you know to replace the injector. As long as its the correct colour/engine size you should be fine
Any thing else?
| Team Impossible Possible
Posted: Sun Sep 16, 2012 7:37 am |
Trade Rating: +16
Addaz wrote: |
Right
Any thing else? |
thanks addaz
i cant get the fault code read again because i had it done when i took it for an m.o.t and the car has no tax, m.o.t, or insurance, i had to get a days insurance to get it there for the m.o.t and i dont want to buy another days just to get the codes read
i need to know what injector im moving because the garage said 4 but when i checked the code myself it said 3? should i just move 3 to 2 and see how it runs?
wont it still run s**t no matter where i move the injector?
looking at the engine head on is injector 3 far left or far right?
Posted: Sun Sep 16, 2012 9:47 am |
How much does 1 injector cost?
Posted: Sun Sep 16, 2012 12:25 pm |
anton1989 wrote: |
looking at the engine head on is injector 3 far left or far right? |
Neither, it's one of the middle ones.
Steve206 wrote: |
How much does 1 injector cost? |
About £70 from the dealer and less than £30 for the ones that you need to replace in a couple of thousand miles.
