Online Now [1334]:
Visitors: 1333
Today: 129205
Total: 151261030
Forums › The Car › 206 Talk › Is my exhaust sitting too low? GTi 180
Forum Index › 206 Talk
cheekyage
PostPosted: Sun May 25, 2014 5:06 am Up
Hi all,
After a quick repair on my exhaust the twin tailpipes seem to be sitting a little further downward than normal.
It looks like they are pointing slightly downward and there is too much gap between the twin tailpipes and rear bumper.
I do remember there was always a slight gap but now when I look at it my hand can reach to the rear of the chrome tailpipes and can see the muffler mounting brackets.
Prior to the exhaust fix, this was not the case.
Here are a couple of pics.
Would appreciated your thoughts and feedback Smile
PostPosted: Sun May 25, 2014 5:25 am Up
is there much movement in it (shaking around etc) ?
PostPosted: Sun May 25, 2014 5:58 am Up
I'd say yes it is mate, this is how it really needs to look
you can either change it for a scorpion or janspeed or just buy some superpro exhaust mounts off ebay, only £13 posted
usher
PostPosted: Sun May 25, 2014 6:58 am Up
could also be the cat or middle box flange being different if they have been changed
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
cheekyage
PostPosted: Sun May 25, 2014 7:50 pm Up
No shaking or movement at all. All has been mounted firmly and correctly.
cheekyage
PostPosted: Sun May 25, 2014 7:56 pm Up
The centre pipe was replaced with a brand new and genuine Peugeot one (part number 1717S9)
All has been fitted to original spec with the original mountings and brackets in located in the same place.
usher
PostPosted: Mon May 26, 2014 2:16 am Up
strange then its usually when bits get changed for non genuine, try the rubbers or cable tie the hangers up without the standard rubbers to see if it will work
project thread WIP
garage
FAQ
206 gti firedance
