Posted: Fri Nov 23, 2012 2:26 am |
the car won't go into gear, and shakes violently when pulling away/changing gear. The clutch is only 6 months old so any ideas what the problem could be?
Cheers
Posted: Fri Nov 23, 2012 4:53 am |
i would checked the engine mount
Posted: Fri Nov 23, 2012 11:34 am |
Did they replace the trust bearing and preassure plate at the same time?
Posted: Fri Nov 23, 2012 3:40 pm |
Is the gear linkage set up properly?
Posted: Fri Nov 23, 2012 3:57 pm |
Does it go into gear when engine is off then started in gear?
