Latest: lio94
Overall: 17181
Online Now [193]:
Visitors: 192
Today: 55906
Total: 141695572
Forums › The Car › Request a how-to › DRL wiring
DRL wiring
Forum IndexRequest a how-to
traffica1
PostPosted: Thu Nov 01, 2012 9:44 am Reply with quote Up
Hello everyone,
i recently ordered these:
any idea of how to wire them and do i need a connector? or i can simply directly the red and black wires ?
You support is much appreciated.
Thank you
iainlovatt
PostPosted: Thu Nov 01, 2012 9:52 am Reply with quote Up
what do you want them to come on with? All the time? , sidelights? Full beam?
ect? If you want them on a switch then you need a switch kit with relay ect.
(My Garage)
traffica1
PostPosted: Thu Nov 01, 2012 9:55 am Reply with quote Up
let's say i want them on all the time, what do i connect them to?
And thank you for your reply.
iainlovatt
PostPosted: Thu Nov 01, 2012 10:01 am Reply with quote Up
If it was me i would wire it into a switch, but i suppose easiest option is just tap into exisiting fogs or headlights, But doing this there will be legal implications. As i suppose they could be classed as foglights, and you can only have them on when foggy, for example.
(My Garage)
traffica1
PostPosted: Thu Nov 01, 2012 10:04 am Reply with quote Up
i see what you mean, and is the switch wiring easy to do by myself?
PostPosted: Thu Nov 01, 2012 10:09 am Reply with quote Up
easy. feed it to the battery, put a relay in between and then power the relay through ignition
iainlovatt
PostPosted: Thu Nov 01, 2012 10:11 am Reply with quote Up
yep,
switch = power
=earth
remote
Relay
power
earth remote>to switch
accessories ie in your case DRL.
done you need somehting like this
clicky
(My Garage)
traffica1
Oh ok thank you guys, i will try that.
But do you think wiring it to the Front fog lamps switch is a good idea?
iainlovatt
PostPosted: Thu Nov 01, 2012 10:14 am Reply with quote Up
Im a huge fan of keeping things separate.
(My Garage)
PostPosted: Thu Nov 01, 2012 10:21 am Reply with quote Up
i hope copper will give you some points if you driving around with fog light on when there is no fog
PostPosted: Thu Nov 01, 2012 11:08 am Reply with quote Up
Are you one of these t***ers that thinks driving around with front fogs on all the time makes you look cool? Rolling Eyes
It doesnt make people look cool, it just makes them look like a total c u n t Wink
juanfernandes
PostPosted: Thu Nov 01, 2012 12:04 pm Reply with quote Up
So DRLs are considered to be fog lights?
Quote::
PostPosted: Thu Nov 01, 2012 12:12 pm Reply with quote Up
They will be if there wired in to the front fog lamp switch as the OP asked in there last comment Wink
Aftermarket drl's are just the latest s**te chav bolt on crap that serves no purpose other then to make companies making / suppling them money.
juanfernandes
PostPosted: Thu Nov 01, 2012 12:18 pm Reply with quote Up
Ah I see, I missed that bit.
Quote::
Abzynthe
PostPosted: Thu Nov 01, 2012 12:39 pm Reply with quote Up
East Area Rep - Abzynthe
I wired mine into a spare slot in the engine bay fuse box, so they came on with ignition and was fused Smile
  Quick Reply
Username:
Message:
Quote the last message
